Crazyflie
Revision as of 06:31, 21 November 2013 by Admin (talk | contribs) (Virtual Machine)
Packaging list
  • Crazyflie control board
  • 5 x CW propellers
  • 5 x CCW propellers
  • 1 LiPo batter(170mAH)
Hardware Specification
Using the Crazyflie
Virtual Machine
