Quadcopter
Packaging list
- Crazyflie control board
- 5 x CW propellers
- 5 x CCW propellers
- 1 LiPo batter
- A crazyradio
- Radio bootloader which enables wireless Update firmware
Before you go ahead and assemble the Crazyflie check the Crazyflie control board and the Crazyradio electronics, Attach a powered micro-USB cable to the Crazyflie control board. It should power up and blink 5 times with the green LED. After that the green LED should be fully on and the red LED should blink. 1.Check the PCB
1.Assembly
2 Start to flying
- Download the client and install it [1]
- If you get error about missing dll, download and install the [2]
- Start up the application
- Insert the joystick and Crazyradio,install the Crazyradio Windows driver [3]
- Before you press connect make sure that the joystick is working as expected
- Press Connect
- Wait for the scanning to complete
- Double-click the Crazyflie you want to connect to. There's one debug URI for UI testing so you should connect to the URI that begins with radio://XX/XX/XX
- The client will now connect to the Crazyflie and handshake
- One the handshake is done you can start flying the Crazyflie. Remember the most tricky part is the thrust so start out easy
Update firmware
The latest firmware for the Crazyflie Nano Quadcopter can be found here [4]
- Make sure that the Crazyflie is disconnected from the client and powered off
- Go to the menu Crazyflie→Bootloader
- Click “Initiate bootloader cold boot”
- Power on the Crazyflie within 5 seconds using the battery (not USB), the booloader should now connect
- Press “Browse” and select the binary you want to download (e.g. cflie.bin)
- Press “Program” and wait
- Press “Restart in firmware mode”
- To check the firmware version, under the View menu, open up Tabs→Console tab and look at the output when connecting to the Crazyflie.
