Quadcopter
Revision as of 06:56, 13 November 2013 by Admin (talk | contribs) (Usage)
1 Introduction 2 Packaging list 3 Hardware Specification 4 Features 5 Usage 6 How to buy
The Crazyflie is a tiny quadcopter often referred to as a nano-quad, built using the PCB itself as the frame. Developed solely by open source tools and designed with development in mind. E.g. we choose 0603 components (resistors & caps) over 0402 to make it easier to replace components. The voltage regulators are adjustable which makes it possible to change the digital and analog supply voltages simply by changing a couple of resistors.
Packaging list
  • Crazyflie control board
  • 5 x CW propellers
  • 5 x CCW propellers
  • 1 LiPo batter
  • A crazyradio
1.Assembly
2 Start to flying
  • Start up the application
  • Insert the joystick and Crazyradio
  •  Before you press connect make sure that the joystick is working as expected
  • Press Connect
Reservd
