Quadcopter
Revision as of 06:13, 13 November 2013 by Admin (talk | contribs)
1 Introduction 2 Hardware Specification 3 Features 4 Usage 5 How to buy
The Crazyflie is a tiny quadcopter often referred to as a nano-quad, built using the PCB itself as the frame. Developed solely by open source tools and designed with development in mind. E.g. we choose 0603 components (resistors & caps) over 0402 to make it easier to replace components. The voltage regulators are adjustable which makes it possible to change the digital and analog supply voltages simply by changing a couple of resistors.
Small and lightweight, around 19g and about 90mm motor to motor Flight time up to 7 minutes with standard 170mAh Li-Po battery Standard micro-USB connector for charging which takes ~20min for the stock 170mAh Li-Po battery Up to 80m range (environment dependent) when using the Crazyradio USB dongle 4-layer low noise PCB design with separate voltage regulators for digital and analog supply
