MPR121 TouchPad
Revision as of 06:46, 17 May 2013 by Admin (talk | contribs) (Document)
The MPR121 capacitive keypad uses the MPR121 and 12 touch sensitive pads to give you a simple 'keypad' with an I2C output. The board also has four mounting holes allowing it to be used as an input system in place of traditional buttons. The 5V - 3.3V level convertor intergrated on this keypad provide you the options for 3.3V and 5V I2C interface for your microcontroller.
  • Low power operation
  • 3.3 V supply operation
  • 12 capacitance sensing inputs
  • Complete touch detection
  • Auto-configuration for each sensing input
  • Auto-calibration for each sensing input
  • Touch/release threshold and debounce for touch detection
  • 3.3V and 5V I2C interface, with Interrupt output
Application
  • Switch Replacements
  • Touch Buttons
  • Touch Keypad
  • Touch Slide bar
  • Touch Wheel
  • Touchpad
  • Touch Panel
  • Near Proximity Detectio
Here is guide illustrate you how to connect MPR121 Touchpad to Arduino.
[Arduno example] [MPR121 datasheet] [MPR121 Touchpad schematic]
Click here to buy MPR121 Touchpad
