Arduino GPRS Shield
Revision as of 03:51, 20 November 2012 by Admin (talk | contribs)
  • GPRS multi-slot class 10/8
  • GPRS mobile station class B
  • Compliant to GSM phase 2/2+
  • RTC supported.
  • Selectable serial port.
  • Speaker and Headphone jacks
Application Ideas
Cautions
Hardware Diagram
Getting Started
Indicator LEDs
Power Up the GPRS Shield
void powerUp()
 pinMode(9, OUTPUT);
 digitalWrite(9,LOW);
 delay(1000);
 digitalWrite(9,HIGH);
 delay(2000);
 delay(3000);
void powerDown()
 pinMode(9, OUTPUT);
 delay(1000);
 delay(2000);
 delay(3000);
UNDER-VOLTAGE WARNNING
OVER-VOLTAGE WARNNING
UNDER-VOLTAGE POWER DOWN
OVER-VOLTAGE POWER DOWN
+CMTE:1
+CMTE:-1
+CMTE:2
+CMTE:-2
Upload Sketch to Arduino
  1. Follow the previously described hardware installation steps to set up the hardware system;
  2. Make sure the GPRS_TX & GPRS_RX jumpers on the GPRS Shield are mounted in SWSerial position - that is we want GPRS_TX to be connected to D7(RX) and GPRS_RX to D8(TX).
  3. Connect the Arduino Duemilanove (or Seeeduino) to your computer using a USB cable.
  4. The ATmega328P microcontroller on Duemilanove board has only one UART which is used for communicating with the PC. What we need is an Arduino Sketch running inside the ATmega328P that would emulate a second serial port (UART) using software on the digital pins D8 and D7 and patch through all the communication between this second software serial port and the actual hardware serial port. By doing this, all the data coming from the computer (connected to the actual hardware UART) would be routed to the GPRS Shield (connected to software UART) then, we would be able to issue AT commands to control the GPRS Shield. The block diagram outlining this scheme is shown below.
//at 19200 bps 8-N-1
#include <SoftwareSerial.h>
SoftwareSerial GPRS(7, 8);
int count=0;     // counter for buffer array
 GPRS.begin(19200);               // the GPRS baud rate
 Serial.begin(19200);             // the Serial port of Arduino baud rate.
 if (GPRS.available())              // if date is comming from softwareserial port ==> data is comming from gprs shield
   while(GPRS.available())          // reading data into char array
     buffer[count++]=GPRS.read();     // writing data into array
     if(count == 64)break;
   Serial.write(buffer,count);            // if no data transmission ends, write buffer to hardware serial port
   clearBufferArray();              // call clearBufferArray function to clear the storaged data from the array
   count = 0;                       // set counter of while loop to zero
 if (Serial.available())            // if data is available on hardwareserial port ==> data is comming from PC or notebook
   GPRS.write(Serial.read());       // write it to the GPRS shield
void clearBufferArray()              // function to clear buffer array
 for (int i=0; i<count;i++)
   { buffer[i]=NULL;}                  // clear all index of array with command NULL
  1. .Upload the sketch to the Arduino board.
  2. .Download and fire up serial tool if you don't have one. Choose the correct COM port for Arduino, and set it to operate at 19200 8-N-1 and then click "Open Com".
  3. .You can power on or off the the SIM900 by pressing the button about 2 second. After power on, the red LED will be on, and the green one beside it will blink and the shield has found the net if it blinks every 3 seconds.
+CFUN: 1
+CPIN: READY
Call Ready
  • Step 2: Sending a text message (SMS)
  1. .Create the setup as described in Step 1 above.
  2. .Through your serial terminal software, send AT+CMGF=1 and press the Enter key. The GPRS Shield can send SMSes in two modes: Text mode and PDU (or binary) mode. Since we want to send out a human readable message, we will select the text mode. The GPRS Shield will respond with an OK.
  3. .Click "send new" option and send AT+CMGS="+918446043032". This will instruct the GPRS Shield to start accepting text for a new message meant for the phone number specified (replace the number with the phone number of the target phone). The GPRS Shield will send a > to remind you typing the message.
  1. .Start typing your message and when you are done, and click "send hex" option and then send a hex: 1A. The modem will accept the message and respond with an OK. A few moments later, the message should be received on the handset whose number you had specified.You can refer to the picture below.
SoftwareSerial library Notes
A Simple Source Code Examples
  1. .With the GPRS Shield removed, download this sketch into your Arduino.
  2. .Disconnect the Xduino from USB port to remove power source.
  3. .Set the Serial Port jumpers on the GPRS Shield in SWserial position, to use the Soft Serial port of Arduino.
  4. .Connect the antenna to the GPRS Shield and insert the SIM Card.
  5. .Mount the GPRS Shield on Arduino.
  6. .Connect the Arduino to the computer by USB, and fire up your favorite serial terminal software on computer, choose the COM port for Arduino, set it to operate at 19200 8-N-1.
  7. .Type command in the terminal to execute different function, threr are 4 functions in the demo:
 ##.If you input 't', the demo will send a SMS message to another cellphone which you set(you need set the number in the code);
 ##.If you input 'd', the program will dial a call to the other cellphone that you set(it is also need you set in the code );
 ##.If you input 'h', it will submit a http request to a web that you want to access(it need you set the web adress in the code), it will    return a string from the website if it goes correctly;
 ##.If you input 's', it will upload the datas to the pachube(for detail you can refer to the explanation in the code). I strongly recommend you input 'h' before input 's', because uploading datas to the pachube need do some setting, after execute the function of submit a http request, the setting will be set.
  1. .If the program returns error in the terminal after you typed the command, don't worry, just try input the command again.
Schematics
GPRSshield_sch.pdf
Resources
SIM900_hd_v1.06.pdf
NewSoftLibrary
GPRS Shield can be ordered through the Getech store. Its product page is located here
