Arduino GPRS Shield
- GPRS multi-slot class 10/8
- GPRS mobile station class B
- Compliant to GSM phase 2/2+
- RTC supported.
- Selectable serial port.
- Speaker and Headphone jacks
Application Ideas
Cautions
Hardware Diagram
Getting Started
Indicator LEDs
Power Up the GPRS Shield
void powerDown() { pinMode(9, OUTPUT); digitalWrite(9,LOW); delay(1000); digitalWrite(9,HIGH); delay(2000); digitalWrite(9,LOW); delay(3000); }
UNDER-VOLTAGE WARNNING
OVER-VOLTAGE WARNNING
UNDER-VOLTAGE POWER DOWN
OVER-VOLTAGE POWER DOWN
+CMTE:1
+CMTE:-1
+CMTE:2
+CMTE:-2
Upload Sketch to Arduino
- Connect the Arduino Duemilanove (or Seeeduino) to your computer using a USB cable.
Examples
- The default Buffer of Rx in NewSoftSerial.h is 32, you may experience some data lose while the returns of SIM900 are many(Receiving SMS/TCPIP), you can try to change the Buffer of Rx in NewSoftSerial.h into
#include <NewSoftSerial.h> NewSoftSerial mySerial(7, 8); void setup() { mySerial.begin(19200); //Default serial port setting for the GPRS modem is 19200bps 8-N-1 mySerial.print("\r"); delay(1000); //Wait for a second while the modem sends an "OK" mySerial.print("AT+CMGF=1\r"); //Because we want to send the SMS in text mode delay(1000); //mySerial.print("AT+CSCA=\"+861032055002\"\r"); //Setting for the SMS Message center number, //delay(1000); //uncomment only if required and replace with //the message center number obtained from //your GSM service provider. //Note that when specifying a tring of characters // " is entered as \" mySerial.print("AT+CMGS=\"+9184460xxxx\"\r"); //Start accepting the text for the message //to be sent to the number specified. //Replace this number with the target mobile number. delay(1000); mySerial.print("Hi from Getech!\r"); //The text for the message delay(1000); mySerial.print(26,BYTE); //Equivalent to sending Ctrl+Z } void loop() { //We just want to send the SMS only once, so there is nothing in this loop. //If we put the code for SMS here, it will be sent again and again and cost us a lot. }
Making a call: using Software UART
#include <NewSoftSerial.h> NewSoftSerial mySerial(7, 8); void setup() { mySerial.begin(19200); // the GPRS baud rate Serial.begin(19200); // the GPRS baud rate delay(2000); mySerial.println("ATDxxxxxxxxx;"); // xxxxxxxxx is the number you want to dial. if(mySerial.available()) { Serial.print((unsigned char)mySerial.read()); } delay(10000); delay(10000); mySerial.println("ATH"); //End the call. if(mySerial.available()) { Serial.print((unsigned char)mySerial.read()); } } void loop() { //Do nothing }
Using AT Commands to Control GPIO and PWM pins
Note: GPIOs,PWMs and ADC of the SIM900 module are all 2V8 logic
#include <NewSoftSerial.h> NewSoftSerial mySerial(7, 8); void setup() { mySerial.begin(19200); // the GPRS baud rate Serial.begin(19200); // the GPRS baud rate delay(2000); } void loop() { mySerial.println("AT+SPWM=1,63,100");// set PWM 1 PIN mySerial.println("AT+SPWM=2,63,50");// set PWM 2 PIN mySerial.println("AT+SGPIO=0,1,1,1");// set GPIO 1 PIN to 1 mySerial.println("AT+SGPIO=0,12,1,1"); delay(1000); mySerial.println("AT+SGPIO=0,1,1,0");// set GPIO 1 PIN to 0 mySerial.println("AT+SGPIO=0,12,1,0"); delay(1000); }
Schematics
GPRSshield_sch.pdf
Resources
SIM900_hd_v1.06.pdf
NewSoftLibrary
GPRS Shield can be ordered through the Getech store. Its product page is located here
