Arduino Mercury Switch Breakout Module
Revision as of 09:50, 14 May 2012 by Admin (talk | contribs) (Usage)
introduction
The Tilt sensor is a digital mercury-based tilt sensor which allows you to detect orientation and inclination. It acts like a switch. When the tilt sensor is in horizontal position, it’s open. When tilt, the switch closed and pass current.
Note
Mercury is toxic substance, Please be careful to avoid breaking the case.
They are small, inexpensive, low-power and easy to use. Their simplicity make them popular for toy , gadget and appliances and many other application.
VCC - 5V
GND - GND
S   - Digital pin3
int ledPin = 13;                // Connect LED to pin 13
int switcher = 3;                 // Connect Tilt sensor to Pin3
 pinMode(ledPin, OUTPUT);      // Set digital pin 13 to output mode
 pinMode(switcher, INPUT);       // Set digital pin 3 to input mode
  if(digitalRead(switcher)==HIGH) //Read sensor value
       digitalWrite(ledPin, HIGH);   // Turn on LED when the sensor is tilted
  else
       digitalWrite(ledPin, LOW);    // Turn off LED when the sensor is not triggered
How to buy it
Click here to buy Tilt sensor module
