Geeetech M1 3D printer
Printer Introduction
Appearance
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
Power Input:
Net Weight(kg): 3 kg
Gross Weight(kg): 4 kg
How to clean the hotend
How to Replace the hotend
How to replace the nozzle
How to Replace the Screen
How to Replace the Extruder
How to Automatically Level
Note: There are 16 leveling points for auto leveling
During the auto leveling process, the nozzle temperature will jump back and forth between 140 degrees and 0 degrees
3、and then turn on auto leveling (this process does not require any operation),
How to Manually Level
How to adjust the X-axis belt
How to remove the upper frame
Mainboard wiring diagram
Black Screen
Minimum Temperature Error
Filament cannot be extruded
3、 The printer is blocked
Solution:
Print file is not displayed
(2) Click Import
(3) Click Import Configs...
4、 Click Yes for all
3.The extruder is not working
Rough edges and corners
The side edges are uneven
How to print PLA
Nozzle temperature: 190-210℃
Bed temperature: 30-60℃
Fan Cooling: 100%
Nozzle temperature: 220-240℃
Fan Cooling: 100%
How to print ABS
Nozzle temperature: 230-250℃
Bed temperature: 90-110℃
Fan Cooling: 0%
How to print PETG
Nozzle temperature: 220-250℃
Bed temperature: 70-80℃
Fan Cooling: 30%
