PIR motion sensor Module
Revision as of 09:38, 7 May 2012 by Admin (talk | contribs) (Usage)
PIR sensors allow you to sense motion, almost always used to detect whether a human has moved in or out of the sensors range. They are small,inexpensive, low-power, easy to use and don't wear out.PIR sensor are basically made of a pyroelectric sensor ,which can detect levels of infrared radiation. Everything emits some low level radiation, and the hotter something is, the more radiation is emitted. The sensor in a motion detector is actually split in two halves. The reason for that is that we are looking to detect motion (change) not average IR levels. The two halves are wired up so that they cancel each other out. If one half sees more or less IR radiation than the other, the output will swing high or low.
Technical parameters
  • Operating voltage: DC5V to 20V
  • Static power consumption: 65 microamps
  • level output: high-5V, low-0V
  • Delay Time: adjustable (0.3 seconds to 18 seconds)
  • embargo time: 0.2 seconds
  • sensing range: less than 120 degrees angle, 7 meters
  • Operating temperature: -15 ~ +70 degrees
When motion is sensed, pin S output 5V.
int pirPin = 2; //digital 2
void setup(){
pinMode(pirPin, INPUT);
pinMode(13, INPUT);
void loop(){
 int pirVal = digitalRead(pirPin);
 if(pirVal == HIGH)
 { //was motion detected
 digitalWrite(13,HIGH);
 delay(500);
 digitalWrite(13,LOW);
 delay(500);
Adjustment
How to buy it
Click here to buy PIR sensor module
