GLA10
Revision as of 08:05, 5 February 2024 by Admin (talk | contribs) (→Leveling test G-code)
GEEETECH GLA10 3D Printer Leveling Auxiliary Tool
GCode generator for GLA10
Tips
① GLA10 is only suitable for 3D printers with leveling nuts on the hotbed.
② Please read this manual carefully for using GLA10 correctly.
③ Please scan the QR code or log in to our website to get the G-code file that GLA10 needs.
④ Please pay attention to safety when leveling the GLA10 hot bed, so as not to hurt your fingers by the moving hot end.
Leveling Preparation
2. GCode generator for GLA10
  Please click the link  https://www.geeetech.com/specialpage/GCode_generator_for_GLA10.html
We provide the corresponding G-codes for different hotbed sizes.Please edit the relevant information in the leveling Gcode generator.
Start Leveling
1. Power on the 3D printer, select the leveling auxiliary G-code pre-installed in the Micro SD, and start the hotbed leveling.The leveling auxiliary G-code will pause at the four corners of the hot bed for 30s respectively. After 30s, the nozzle will move to the next point. After the pause at the fourth corners, the printer will exit the leveling.
4. After leveling, please use the Leveling test G-code to verify the leveling effect.If any problem is found during the leveling test, please re-level the hotbed.
install Cura
install plug-in
3.Please find the submenu "Auto Towers" in the Cura main menu "Extensions" ,then click "Custom Bed Level Pattern" and select "Bed Level Pattern Type"according to your preference.
4.Please set the initial layer height and click "slice" to generate a leveling test Gcode.
slice
Product Parameters
Battery parameter:CR2032,3V
Product weight:14.5g
Packing weight:52g
