Geeetech Mizar Pro 3D Printer
Revision as of 08:32, 24 July 2023 by Admin (talk | contribs) (→How to clean the hotend)
Printer Introduction
Mizar Pro owns dual leveling technology, its printing accuracy is higher and the hot bed has been fixed, so don't worry about the hot bed being deformed or loosened. Its build volume is 220*220*260mm, and the appearance is more concise and beautiful, which can meet most of your printing needs!
Precise Auto leveling GEEETECH Mizar Pro has dual-leveling system, which enables one-button ABL automatic bed leveling technology. It is equipped with a high-precision leveling sensor and no need for external leveling accessories like BL touch.
It also creatively designed manual leveling mode, which is more friendly to beginners, amateurs and specialists.
Stable Magnetic Platform The heat bed adopts a fully fixed design, The hot bed can be used for a long time after leveling once with the leveling sensor, do not need frequently leveling the hot bed;The hot bed printing platform adopts the magnetic suction method. Compared with the ordinary magnetic printing platform, the top component of the Mizar Pro printing platform is made of metal material, it is durable and easy to remove the model.
Super Silent Driver The Mizar Pro motherboard uses a high-performance 32-bit MCU with faster printing speed. TMC2208 silent driver can effectively reduce the noise of stepper motor than Atmega2560, the printing sound doesn't exceed 50 dBs, which will not disturb your and others work, study and rest.
Resume Printing Function This 3d printing machine can detect interruptions of power failure, filament run out or stuck, it will automatically pause and save the printing progress, when you handle the exception, it'll resume the previous printing task, which gives your printing work an extra layer of protection.
Main Specification
Printer Type FDM
Layer Thickness 0.1-0.3 mm
Building Platform Volume 220*220*260 mm
Auto-leveling Yes
Break Resuming Yes
Preheat time(110℃) 11 min
Nozzle Diameter 0.4 mm
Printing Accuracy ±0.1 mm
Supported File Format .gcode
Hotbed Max. Temperature 110 ℃
Printing Size 220*220*260 mm
Net Weight(kg) 8.9 kg
Gross Weight(kg) 9.6 kg
Printer Whole Size 462(W)*515(L)*445(H) mm
Packing Dimension 512(L)*512(W)*274(H) mm
How to auto leveling
How to auto leveling Z offset
How to manual leveling
How to replace PSU
How to replace motherboard
Mintemp error
Filament sensor
How to update:
4.Update is complete.
Notice:
Nothing is printing
Automatic leveling failed
(a)Nozzle calibration failed You should use a scraper against the nozzle and gently push up to make the nozzle “feel” the pressure. If this still fails, check if the strain gauge in the hotend is connected properly, and ensure the cables are not broken.
(b)Homing failed Check the X, Y and Z axes end stops, make sure they’re all connected properly. Note the photoelectric end stops on the Y and Z axes, which normally have a blue signal light.
(c)The first layer is messy Please clean the hotbed before printing, this will help to get a good adhesion. We recommend a thicker first layer, 0.3 mm is good. If these’re not helpful, please try to adjust the Z-offset. What’s more, you can try adjust the hotbed temperature, for example, the Geeetech wood PLA needs a lower temperature but PETG needs higher.
The printer is unstable
Make sure you put the printer on a stable platform, then check if the gantry kit is tightened. Make sure the four rubber mats are all tightened.
Spring steel sheet problem
(d)A low-tension extruder arm bar. If spring tension is too low, the extruder gear will not properly grip the filament. This leads to filament grinding.
(e)Check if the grub screw on the extruder gear. If the grub screw is loose, the gears will fail to grab the filament when feeding into the hotend.
(a)Please check if the power supply is working normally. The red indicator on the switch should be light. Please measure the output voltage, which should be around 24 Volts.
(b)Check the fuse in the little black box, it should be complete without burns. Also check if the power supply connector is burn out or connected tightly.
(c)Please check if the control board is working normally. There’re one green LED and one red LED working as the picture shown below. Measure the input voltage of the control board, it should be around 24 Volts.
(d)Make sure the screen is connected properly.
The thickness of the first layer printed is uneven
Rough edges and corners
The side edges are uneven
Nozzle temperature: 220-230℃ Bed temperature: 30-60℃ Print speed: 30-40mm/s Initial print speed: 20mm/s Retraction: Disabled
How to print ABS
Nozzle temperature: 230-250℃ Bed temperature: 90-110℃ Print speed: 50-60mm/s Initial print speed: 20mm/s Number of slower layers: 5-10 (The first few layers are printed slower that the rest of the model, to get better adhesion to the build plate.)
Fan speed: 0%
Build plate adhesion: Brim Raft shield: Enable
How to print PETG
Nozzle temperature: 220-250℃ Bed temperature: 70-80℃ Print speed: 40-50mm/s Initial print speed: 20mm/s Travel speed: 120mm/s
Retraction distance: 6mm for Bowden setups, 2-3mm for direct drive setups Retraction speed: 25-45mm/s Fan speed: 30% Initial fan speed: 0% Build plate adhesion: Brim The recommended parameters are slightly different for different brands of filaments. We can provide you with test models. PETG is hygroscopic. Try using a container or resealable bags.
