Arduino SD card Module
Revision as of 03:07, 7 May 2012 by Admin (talk | contribs)
The Arduino SD Card Shield is a simple solution for transferring data to and from a standard SD card. The pinout is directly compatible with Arduino, but can also be used with other microcontrollers. It allows you to add mass storage and data logging to your project.
  • Break out board for standard SD card and Micro SD (TF) card
  • Contains a switch to select the flash card slot
  • Sits directly on a Arduino
  • Also be used with other microcontrollers
Connection Diagram
example code
#include <SD.h>
const int chipSelect = 4;
 Serial.print("Initializing SD card...");
 // make sure that the default chip select pin is set to
 // output, even if you don't use it:
 pinMode(10, OUTPUT);
 // see if the card is present and can be initialized:
 if (!SD.begin(chipSelect)) {
   Serial.println("Card failed, or not present");
   // don't do anything more:
   return;
 Serial.println("card initialized.");
 // make a string for assembling the data to log:
 String dataString = "";
 // read three sensors and append to the string:
 for (int analogPin = 0; analogPin < 3; analogPin++) {
   int sensor = analogRead(analogPin);
   dataString += String(sensor);
   if (analogPin < 2) {
     dataString += ",";
 File dataFile = SD.open("datalog.txt", FILE_WRITE);
 if (dataFile) {
   dataFile.println(dataString);
   dataFile.close();
   Serial.println(dataString);
 else {
   Serial.println("error opening datalog.txt");
click here to buySD card
