Geeetech B30 3D Printer
Revision as of 05:28, 27 January 2018 by Admin (talk | contribs) (→Feature)
Geeetech B30, a fully-featured new 3D printer, is worthy of the name “The beast behind the beauty”. Pursuing simplicity and gentility, B30 prints 2-3 times faster than the average printers, without sacrificing the printing quality and mechanical performance.
The whole frame is built in black and white, imparting its unique noble temperament. The touch screen and Geeetech logo at the racetrack-shaped area is in harmony with the design of the extruder and the whole frame. The backlight Notification, a considerable add-on, could show the printing status of B30 in time. Its overall appearance renders this new device appealing at the first sight.
B30 is highly modularized and the main components could be put together within minutes. Made from sheet metal, B30 runs stably, totally getting rid of failed printing caused by vibration. The power supply unit, control board and wires are enclosed at the bottom of the machine, which helps to reduce unnecessary dangers, lower the gravity center and further stabilize the whole machine.
This new machine, with its build volume of 320*320*350mm, provides enough room for you to unleash your creativity and turn abstract models into palpable items. The layer resolution is up to 0.05mm, which could ensure that the printer delivers items with nice layer adhesion, smooth surface finish and solid structure. Besides, the extruder is of remote style, ensuring that the printing head could move quickly, accurately and stably.
B30 adopts a 3D touch to auto level and calibrate the hotbed. This kind of leveling method seems easier and more effective than the auxiliary one. The 3.2″ full-color touch screen, intuitive and easy-to-manage, empowers you to take control of the printer at your fingertips. With a few clicks, it is straightforward to modify the relevant parameters, select a model from TF card and start to print.
Its break-resuming capability and filament detector make B30 more considerate enough to enhancing your printing experience. The former helps you to stop the machine and save the real-time printing status when the power fails, and allows you to assume the unfinished print next time. The latter would notify you of changing filament in time in case the printing material runs out.
In addition, B30 could be controlled by TF card, Wi-Fi enabled EasyPrint 3D App and our self-developed printing and control software EasyPrint 3D.
B20 could print with an assortment of filaments, including ABS, PLA, Nylon, wood polymers, etc. Hence add much more joys to your printing.
Feature
1. Simple & Noble
The whole frame is built in black and white, imparting its unique noble temperament. The touch screen and Geeetech logo at the racetrack-shaped area is in harmony with the design of the extruder and the whole frame. The Backlight Notification, a considerable add-on, could show the printing status of B30 in time. Its overall appearance renders this new device appealing at the first sight.
2. Easy to Assemble
To save the building efforts on your part, B30 is designed highly modularized. The main components could be put together within minutes.
3. Strong & Stable
Made from sheet metal, B30 runs stably, totally getting rid of failed printing caused by vibration. Besides, the power supply unit, control board and wires are enclosed at the bottom of the machine, which helps to reduce unnecessary dangers, lower the gravity center and further stabilize the whole machine.
4.High Printing Precision
B30 keeps the same high printing precision of 0.05-0.3mm as its predecessors. Able to deliver prints with smooth surface, clear angle, sleek contour and sturdy structure.
5.Ultra-Fast Printing Speed
Using high-performance steppers, B30 prints 2-3 times faster than the average printers, without sacrificing the printing quality and mechanical performance.
Printing at the same high speed
B30 extrudes smoothly, delivering fine and exquisite surface finish and clear curves.
However, the ordinary printers are prone to missing steps and the prints are coarse and have severe errors in each layer.
6.Better adhesion
a. Silicon carbide glass with microporous coating b. No need to attach masking tape c. High chemical stability, uniform heating and good wear-resistance d. Microporous coating: inorganic, a hardness of 8 Mohs and high durability e. Better adhesion and flatness and easy to take prints off f. Easy to clean with water or alcohol
Silicon carbide platform: Better adhesion and durable. Taking down your print is a piece of cake! No need of masking tape and glue sticks.
Ordinary platform: Really really need masking tape and glue sticks. Hard to take down your print without a scraper knife. Easy to be scratched.
7. Cloud-based EasyPrint 3D App
EasyPrint 3D App comes fully featured.
A cloud gallery of 50,000 free 3D models, cloud slicer, BUZZ, compatible with different 3D printers, remote control over multiple printers and instant notifications. Complete with these 6 user-oriented characteristics, EasyPrint 3D would assist you in exploring the cloud 3D printing era.
Cloud Gallery
A total of 50,000 FREE 3D models, covering 9 categories, are ready for you to enjoy an amazing 3D printing feast. Practical, fantastic & convenient.
Cloud Slicer
You just need to scroll through the gallery, choose your favorite and complete simple setting. EasyPrint 3D will autonomously take over the seemingly sophisticated slicing job. Cloud 3D printer is really on your palm.
Buzz
---share & news feed---
After finishing your print, even a simple gadget, nothing is more thrilling than sharing it at once.
EasyPrint 3D totally reads your mind!
SHARE your unique work with worldwide friends via a swipe of fingers.
Get to know the latest industry news, practical articles and videos, interesting contests, discounts, contests, etc.
Remote Control
EasyPrint 3D allows you to adjust the printing speed, fan speed, heatbed and extruder temperature, etc. anywhere and anytime. Totally help you say goodbye to a printer-sitter.
8. 3.2″full-color touch screen
9. Break-resuming Capability
The break-resuming capacity, a resurrection system, is added to save real-time printing status and resume the printing job exactly at the same place where it has been stopped.
This add-on totally drives away the hassle of repetitive and time-consuming printing jobs caused by unexpected power outage. Totally get you out of worries about printing large-size 3D models.
10. Filament Detector
11. SD Card Stand-alone Printing
B30 could print stand-alone with a tiny TF card. You just need to choose a 3D model file from SD card, set the relevant printing parameters and start to print. Explore the fabulous 3D printing world with a swipe of your fingers!
12. Software Resources
   Self-developed EasyPrint 3D
   On-line Firmware Upgrade
13. Open Filament System
B30 is compatible with a wide range of filaments, covering PLA, ABS, nylon, flexible PLA, wood polymers, etc. Different colors and texture give you innumerable possibilities to explore the fantastic 3D printing world.
14. Certifications
B30 has obtained the relevant certificated for its international safety, such as CE, FCC, PSE, etc.
Gallery
Video
