Geeetech A30 3D Printer
Revision as of 05:21, 17 November 2017 by Admin (talk | contribs) (→Software)
1. The biggest printer ever
2. 3.2″ full-color touch screen Intuitive & Easy-to-use
3. Better adhesion
We choose tempered glass with microporous coating as A30 building platform. The special coating is inorganic and has a hardness of 8 Mohs, hence of high durability. Compared with aluminum plate, this kind of tempered glass is of better adhesion and flatness and easy to take prints off by hand or with the help of a scraper. Besides, it is easy to clean with water or alcohol.
4. 3D touch auto-leveling (Optional add-on)
5. Break-resuming capability
6. Filament detector
7.Wi-Fi enabled EasyPrint 3D App Convenient & Multifunctional
Remote control
8. Download EasyPrint 3D App
11. Upgrade firmware on-line
12. Good craftmanship
13. Bowden Extruder Remote design & Stable performance
15. Easy to assemble
16. Product display
Gallery
Videos
View Geeetech A30 3D Printer Playlist on Youtube
Geeetech A30 3D Printer User Manual
