Building Instructions of Geeetech Prusa I3 M201
Revision as of 03:38, 31 October 2015 by Admin (talk | contribs) (→Add the belt)
Preparation
450mm threaded rod
No.5
2
M10 washer
No.9
8
M10 hex nut
No.13
8
M10 spring washer
No.10
6
Connecting fender
No.A14
2
Watch the Video here.
M10 washer
No.9
4
M10 hex nut
No.13
4
Y axis front support
No.A9
1
No.A10
1
Y axis rear support
No.A11
1
Y axis rear support
No.A12
1
  • Tips:
You can watch the video here.
SCS8UU Linear Bearing
No.40
4
420mm Smooth rod
No.3
2
locking ring
No.37
2
Screw up the locking ring
watch video here
Mount the Y motor
stepper motor
No.65
1
Y motor holder
No.A13
1
M3 x12mm screw
No.25
3
M3 x 16mm screw
No.26
2
M3 washer
No.7
5
M3 square nut
No.17
2
Pulley
No.45
1
Y belt driving wheel
Driven wheel holder
No.42
1
Driven wheel
No.43
1
R84zz Ball Bearing
No.44
2
M3 x20mm screw
No.35
1
M4 x 25mm screw
No.17
1
M3 washer
No.7
1
M4 washer
No.8
1
M4 lock nut
No.14
1
wing nut
No.15
1
Build the print platform
Building platform support
No.A15
1
Belt mount
No.38
1
M3 x12mm screw
No.25
2
M4 x 16mm screw
No.34
16
M3 washer
No.7
2
M4 washer
No.8
16
Mount the Y belt
Timing belt
No.46
1
M3 x8mm screw
No.23
2
M3 washer
No.7
2
  • Tips:
Watch the video here.
Left Z motor mount
M3 x 16mm screw
No.26
5
M3 Square nut
No.17
5
M3 washer
No.7
5
Motor holder (left)
No.A4
1
Motor Holder support
No.A6
1
No.A7
1
Main frame
No.A1
1
  • Be very careful here, if you can not insert them into the hole you can loose the screw on the motor mount and try again.
Right Z motor mount
M3 x 16mm screw
No.26
5
M3 Square nut
No.17
5
M3 washer
No.7
5
Motor holder
No.A5
1
No.A6
2
Side panel assembly
M3 x 16mm screw
No.26
6
M3 Square nut
No.17
6
M3 washer
No.7
6
Side panel(left)
No.A2
1
Side panel(right)
No.A3
1
Mount the Z motors
stepper motor
No.65
2
M3 x12mm screw
No.25
8
M3 washer
No.7
6
Mount the Z endstop
M2.5 x 16mm screw
No. 22
2
M2.5 hex nut
No. 11
2
End stop
No.54
1
Main frame assembly
M3 x 16mm screw
No. 26
2
M3 x 20mm screw
No. 17
4
M3 hex nut
No.12
4
M3 square nut
No. 17
2
M3 washer
No.7
6
Fan mount
M3 x 25mm screw
No. 28
4
M3 hex nut
No. 12
4
M3 washer
No.7
6
Fan
No.52
1
Mount the couplings
Coupling
No.48
2
watch video here.
Z-axis nut
No.16
1
X-axis motor end
No.M1
1
Linear Bearing LMH8LUU
No. 41
1
M3 x 30 screw
No.28
1
M3 x 6mm screw
No. 22
8
M3 washer
No. 7
2
Spring
No. 36
1
mount the X motor
M3 x 6 mm screw
No.22
3
Stepper motor
No.65
1
Pulley
No.45
1
Mount the endstop
M2.5 x 8 mm screw
No. 20
2
End stop
No.55
1
Z-axis nut
No.16
1
X-axis idle end
No.M2
1
No. 41
1
M3 x 6mm screw
No. 22
8
X Carriage
No.M3
1
Bearing Bracket
No.M4
4
Extruder holder
No.M5
1
Linear BearingLM8LUU
No.40
2
Belt bracket
No.47
1
M3x6mm screw
No. 22
10
M4x6mm screw
No. 32
2
M3 nut
No.12
2
Assemble the the X&Z axis
L300mm threaded rod
No.4
2
L322mm smooth rod
No.1
2
L455mm smooth rod
No.2
2
locking ring
No.37
4
  • Keep both end of X axis at the same place of the rod, you are advised to measure the distance of the both side so that they are at the same level when you put them up.
  • Note: The smooth rods and the threaded rod of Z axis is vertical, and the X axis is horizontal ,which is very important, or it will hinder the move of the Z axis.
Assemble the Z axis top mount
Z top mount
No.A8
2
M3 x 16mm screw
No.23
6
M3 Square nut
No.17
6
locking ring
No.37
2
M3 washer
No.7
6
X belt driving wheel
Driven wheel holder
No.42
1
Driven wheel
No.43
1
R84zz Ball Bearing
No.44
2
M3 x20mm screw
No.35
1
M4 x 25mm screw
No.17
1
M3 washer
No.7
1
M4 washer
No.8
1
M4 lock nut
No.14
1
wing nut
No.15
1
Watch video here.
Add the belt
Timing belt
No.46
1
Belt bracket
No.47
1
watch video here.
Mount the hotend
Hotend
No.66
1
M4x6mm screw
No.32
2
M4 washer
No.8
1
Mount the control board
Control board kit
No.68
1
Sticker
No.56
1
Heat sink
No.55
1
Spacer
No.49
4
M3 x 12mm screw
No.25
4
M3 washer
No.7
1
Here is the video.
Power supply Unit
No.61
1
3D Power Cable
No.62
1
M4 x 12mm screw
No.33
3
M3 x 16 Hex Counter-sunk-head screw
No.19
2
M3 hex nut
No.12
2
M4 washer
No.8
1
Power Cable
No.63
1
Color of wire connectorD
Brown
L
Blue
N
Yellow
GND
Red
+ V
Black
COM
Mount the LCD panel
LCD 2004
No.67
1
Knob
No.50
1
Spacer
No.49
4
M3 x 12mm screw
No.25
4
M3 washer
No.7
1
Step 3. Screw up the knob .
  • Pay attention to the two connectors at the back of the LCD.
EXP 1 is for the LCD.
EXP 2 is the SD card reader.
Do not mix them up.
Here you can watch the video.
Mount the building platform.
Thermometry & Heating wire
No.58
1
Heatbed set
No.59
1
Building platform
No.60
1
wing nut
No.16
4
No.19
4
Spring
No.36
4
watch video here.
Wiring
4) Connect Extruder motors
Connect extruder 0.
Step4. Connect heating wires.
  • There is no “+” and “-“ polarity for heating wires
  • There is no “+” and “-“ polarity for endstop
Step7. Connect wires for Fan.
Red: +
Black: -
Brown------L
Blue ------N
Yellow------GND
Red ------ --+ V
Black------COM
Mount the filament spool
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
M3 washer
No.7
6
Spool base plate
1
Spool side pane
2
PVC tube
1
PVC tube
2
Each machine may have its own calibration procedure and this manual will not attempt to cover all the variations. Instead here is a list of key points that should be addressed. 
  • Belts are taut.
