Building Instructions of Geeetech Prusa I3 M201
Preparation
Watch the Video here.
- Tips:
You can watch the video here.
Screw up the locking ring
Mount the Y motor
Y belt driving wheel
Build the print platform
Mount the Y belt
- Tips:
Watch the video here.
Left Z motor mount
*Be very careful here, if you can not insert them into the hole you can loose the screw on the motor mount and try again.
Right Z motor mount
Side panel assembly
Mount the Z motors
Mount the Z endstop
Main frame assembly
Fan mount
Mount the fan on the BACK of the left side of the A1. Fix it with 4 M3 x 30mm screw, M3 washer and 4 M3 hex nut.
Mount the couplings
1.Thread a M3 washer> spring> M3 washer in order to the M3x50mm screw.
mount the X motor.
Step 3. Mount the endstop
Assemble the the Z axis
X belt driving wheel
Add the belt
Mount the hotend
Mount the control board
Here is the video.
| Color of wire | connectorD |
Mount the LCD panel
Step 3. Screw up the knob .
EXP 1 is for the LCD.
EXP 2 is the SD card reader.
Do not mix them up.
Here you can watch the video.
