Geeetech G2 & G2s pro Building instruction
Revision as of 00:47, 15 October 2015 by Admin (talk | contribs)
Geeetech rostock mini G2S upgrade kit
Media:Geeetech rostock mini G2S upgrade kit.pdf
this kit include all the parts you need to upgrade your G2 & G2s into this pro version. but if you want to upgrade your G2 into a G2s pro, that is from a single extruder to a dual extruder version, you will need other parts. such as the extruder,and the PTFE feeding pipe. one more A4988 stepper motor driver board ect.
Preparation
9. There are step-by-step videos for you to refer, please combine this instruction with the video to help you finish the work. For instruction videos, please subscribe our YouTube Channel.
Base Assembly
Motor holder assembly
Motor holder
NO.A3
3
Motor holder support
NO.A4
6
Square nut
NO.13
6
M3 x 16 Screw
NO.20
6
M3 washer
NO.5
6
Step1. Assemble A3 and 2 A4 together, and screw up with M3 x 16 screws, M3 square nut and M3 washer.
Repeat the steps for the other 2 motor holders.
Base plate
NO.A2
1
Square nut
NO.13
9
M3 x 16 Screw
NO.20
9
M3 washer
NO.5
21
Stepper motor
NO.55
3
Pulley
NO.34
3
M3 x 12 Screw
NO.19
12
Step1. Mount the motor end to the 3 tower of the base plate (A2 ). Fix them with 9 M3 x 16 Screws, Square nuts and M3 washers.
Step2. Mount the pulley on the motor shaft, one of the screws should be screwed on the cross section, the flat side of the shaft. Screw it tightly.
Step3. Mount the 3 assembled motor to the motor holder; screw it up with M3x12 screws and M3 washers.
  • Note the direction of the wire connector, it is better to be on the either left or right side.
Mount the LCD panel
LCD frame
NO.A8
1
LCD support
NO.A9
1
LCD2004
NO.49
1
Square nut
NO.13
4
M3 x 16 Screw
NO.20
4
M3 x 12 Screw
NO.19
4
Spacer
NO.37
4
M3 washer
NO.5
8
Knob
NO.48
1
Step1. Assemble the LCD frame and support plate together, screw up with M3 x 16 Screws and M3 square nuts.
Step3. Screw up the frame and LCD2004 with 4 M3 x 12 Screws and washers.
Step5. Mount the assembled LCD kit onto the base plate. Screw it up with 2 M3 x 16 screws, M3 square nuts and washers.
Mount the fan
Fan(40x40x10)
NO.45
1
M3 x 16 Screw
NO.20
1
M3 x 25 screw
NO.22
2
M3 Square nut
NO.13
1
M3 nut
NO.10
2
M3 washer
NO.5
3
Step1. Mount the fan on the fan mount; screw it up with 2 M3 x 25 screw and M3 nut and washer.
Step2. Mount the assembled fan mount on A2 with a M3 x 16 screw and M3 square nut and washer.
Mount the control board.
Control board GT2560 set
NO.50
1
Spacer
NO.37
4
M3 x 12 Screw
NO.19
4
M3 washer
NO.5
4
Step1. Plug the aircraft- type spacer into the 4 screw hole on the control board from back to front
Step2. Screw the control board to the base plate (A2) with 4 M3 x 12 Screws and m3 washer.
Note the fan is better to be towards the MOSFET of the board.
Mount the print bed.
Building platform
NO.M8
1
Heatbed
NO.54
1
Hex Counter-sunk-head screw
NO.14
3
Spring 3.5 x 20mm
NO.28
3
Wing nut
NO.12
3
M3 washer
NO.5
6
  • for your convenience, the heatbed for you is pre-soldered, you can mount them directly.
Step2. Thread the M3x30mm Hex Counter-sunk-head screw through the two plates and add washers and spring at this end.
Here is the finished picture.
Top Plate Assembly
Drive wheel mount
Drive wheel mount
NO.A5
3
M3x25 Screw
NO.22
6
M3 nut
NO.10
6
M3 washer
NO.5
6
Step1. Mount the Drive wheel mount on A1; screw them up with M3 x 25 screws, M3 nut and washers.
Repeat for the other two.
Endstop mount
Top plate
NO.A1
1
Endstop mount
NO.A6
3
Endstop
NO.44
3
M2.5 x 16 screw
NO.17
6
M3 x 16 Screw
NO.20
3
Square nut
NO.13
3
M3 washer
NO.5
9
M2.5 nut
NO.9
6
Step1. Mount the three end stops onto the Endstop mount (A6) in the same direction, screw with M2.5 x 16 screws and M2.5 nut tightly
Step2. Bent the wire connector a bit.
You should do it very gently and note the direction, or it will break easily.
Step2. Mount the assembled parts onto the top plate. Screw up with M3 x 16 screws, M3 square nuts and M3 washers. Again,note the directions of the endstop.
  • The opening of the endstop should be in clockwise direction or anti-clockwise direction.
Assemble the carriage
Carriage mount
NO.A12
3
Belt mount
NO.M5
3
Endstop trigger mount
NO.M6
3
Diagonal Rod joint
NO.M7
6
SCS10UU Linear Bearing
NO.35
6
M3x8mm Screw
NO.18
6
M3x12mm Screw
NO.19
12
M5x16mm Screw
NO.27
24
M3x40mm Screw
NO.23
3
Spring
NO.29
3
M3 washer
NO.5
24
rod-end bearing holder
NO.3
6
Step1. Fix the belt mount on the A12 with 2 M3 x12 screws and washer.
Step2. Fix the Endstop trigger mount on the other side of the A12 with 2 M3 x 12mm screws and washer.
Step3. Connect the diagonal rod joint and the SCS10UU linear bearing with the A12 in between. Fix it up with 8 M5x16mm screws.
Note the direction of the diagonal rod joint, the wider edge is near the Endstop trigger mount.
Step3. Put the M3x40mm screw into the Endstop trigger mount with a spring in between. Here you need to use washers
Repeat the steps for the rest two carriages.
The 3 carriages should be exactly the same.
Step4. Insert the rod-end bearing holder into the diagonal rod joint, fix it with a M3x8mm screw and M3 washer.
Repeat the step for the other 2 carriages.
Assemble the print platform
mount the fan
Spider
NO.M1
1
Fan(30x30x10)
NO.47
1
Fan mount
NO.M2
1
M3 x 16 screwt
NO.20
2
M3 x20 screw
NO.21
2
M3 washer
NO.5
2
Step1. Screw the fan onto the slant side of the fan mount with 2 M3x 20 screws and M3 washers.
Step2. Mount the assembled fan mount on the spider with 2 M3 x16mm screws.
Mount the Probe mount
Probe mount
NO.M4
1
M2.5 x 16 screw
NO.17
2
Mount the Probe mount on the spider with 2 M2.5 x16mm screws from bottom to up.
Mount the rod-end bearing holder and diagonal rod
Diagonal Rod
NO.4
6
NO.3
6
Round head screw with pad
NO.15
6
M3 washer
NO.5
6
M3 x 8 screw
NO.18
6
Step1.Insert the rod-end bearing holder into the diagonal rod joint on the spider, fix it with M3x8mm screw and M3 washer.
Step2. Fix the Diagonal Rod on the rod-end bearing holder with Round head screw with pad.
Mount the endstop and the probe.
Endstop
NO.44
1
Probe
NO.43
1
Spring(3.5*30)
NO.29
1
Probe Lock ring
NO.M3
1
M2.5 x 8 screw
NO.16
2
Step1. Mount the endstop on the spider close to the probe mount with 2 M2.5 x 8 screws.
Step2. Put the probe into the probe mount and lock it with a lock ring and spring.
Mount the hotend.
Hotend
NO.57
1
M4 x 16 screw
NO.25
2
Mount the hotend on the spider with 2 M4 x 16 screws.
Mount the smooth rods
Smooth Rod
NO.1
6
M4 x 8 Screw
NO.24
6
M8 Washers
NO.8
6
M4 washer
NO.6
6
Step1. Put a M8 washer on the end of the smooth rod.Insert the rods into the holes on the base plate;
Step2. Screw up the rods with M4x8 screws ans M4 washers.
Repeat the above two steps for other 5 rods.
Mount the carriage and the top plate
M4 x 8 Screw
NO.24
6
M8 Washers
NO.8
6
M4 washer
NO.6
6
Step1 Slide carriages into the 6 smooth rods separately.
  • When you do this, you’d better take the top plate here to check if the long screw on the carriage will hit on the opening of the endstop when the carriages raised up.
  • If you find it difficult to slide the carriage to the rod, or it cannot slide smoothly,
you can loose the screws on the linear bearings a bit.
Step2. Put a M8 washer on each top end of the rods and cover the top plate on the rods, screw them up with M4x 8 screws and M4 washers
Mount the Belt
Assemble the driving wheel
Driven wheel holder
NO..33
3
Driven wheel
NO..32
3
R84zz Ball Bearing
NO..31
6
M3 x16mm screw
NO..20
3
M4 x 25mm screw
NO..26
3
M4 washer
NO..6
3
M4 lock nut
NO..11
3
wing nut
NO..12
3
Step1. Thread the M3 x 16 screw through the Driven wheel holder.
Repeat the steps for the other 2 driven wheel.
Add the belt
Timing Belt
NO.36
3
M3 x8 Screw
NO.18
6
M3 washer
NO.5
6
Step2. Fix one end of the belt on the belt mount with a M3x8mm screw and M3 washer.
Step3 Pull down another end of the belt to the pulley. Twist the the belt around the pulley, taut the belt to the other end of the belt mount. fix it with a M3x8mm screw and M3 washer.
  • Before you cut the belt, be sure you are sure about the length, it is about 110cm.
Step4 Tighten the wing nut to taut the belt.
Connect the Diagonal Rod to the carriage
NO.15
6
Connect the Diagonal Rod on the assembled print platform to the carriage.
  • Note. The auto-leveling device is towards the X tower, as shown in the picture.
Mount the extruder
Lets take the dual extruder as example.
Extruder
NO.56A&B
2
M5 x 16 screw
NO.27
8
Find out the locating holes on the top plate; screw up the extruder with 8 M5 x 16 screws and washers from bottom to up.
Mount the filament holder
This step can also be finished at last if you like
Spool holder Side panel
NO.A10
1
NO.A11
1
M3x16 screw
NO.20
4
Square nut
NO.13
4
locking ring
NO.30
2
Screw up A10 and A11 on the top plate separately with M3x16 screw,M3 square nut and washer.
EXAMPLE 1: G2
EXAMPLE 2: G2S
For this dual filament spool, you need to use the locking ring to lock the spool on both end.
Connect the feeding pipe
Feeding pipe
1
1
Step1. Plug one end of the tube into the push-fitting on the hotend and the other end into that of the extruder.
Before connecting the pipe, you need to match the extruder and the hotend:
The positive extruder is refered to as no.1, and the reversed extruder is no.2,
  • If you need to pull the tube out, please press the blue part while pulling.
Wiring
4) Connect extruder
Step4. Connect heating wires.
endstop
41
3
Step6. Connect wires for Fan.
Power cable
48
1
3D Power cable
49
1
As shown in the red box.
Tidy out the wires
Use the spiral coil and zip ties to put those wires together.
If you tidy up the wires first before wiring,you are advised to mark each wires or connectors in case you mix them up.
So far, the Rostock mini G2( G2s) has been fully assembled.
Tips
Before even attempting the first print it is vital that the printer is correctly calibrated. Skipping or rushing this step will result in frustration and failed prints
later, so it is important to take the time to make sure the machine is correctly set up.
Each machine may have its own calibration procedure and this manual will not attempt to cover all the variations. Instead here is a list of key points that should be
addressed.
Frame is stable and correctly aligned.  Rods are correctly aligned 
Belts are taut.
Driving wheel turns smoothly  Bed is level in relation to the path of the extruder.  Filament rolls freely from the spool, without causing too much tension on the extruder.  Current for stepper motors is set to the correct level.  Wires are correctly connected  Couplings and pulleys are fixed tightly
Firmware settings are correct including: axis movement speeds and acceleration; temperature control; end-stops; motor directions.
Extruder is calibrated in the firmware with the correct steps per mm of filament.
The point regarding the extruder step rate is vital. Slic3r expects that the machine will accurately produce a set amount of filament when told to do so. Too much will
result in blobs and other imperfections in the print, too little will result in gaps and poor inter-layer adhesion.
