Altera CycloneII EP2C5T144 FPGA Dev Board
Revision as of 09:35, 19 March 2012 by Admin (talk | contribs) (Created page with " == Features: == - Can be embeded to any of your FPGA Application! - Based on Altera EP2C5T144 FPGA chip - Configuration EPROM chip EPCS4, size 4Mbit - Onboard 50M active patc...")
- Can be embeded to any of your FPGA Application! - Based on Altera EP2C5T144 FPGA chip - Configuration EPROM chip EPCS4, size 4Mbit - Onboard 50M active patch oscillator (crystal oscillator in the board's back) - 5V power supply - The board has the power indicator light and reset switch - Onboard 3 SMD LED - All the IO ports and clock pin through the pin to bring out (any of these interfaces can be used for memory and peripheral expansion) - High-quality tantalum capacitor power supply filtering - The development of embedded CPU support NiosII - -Board size: 61mm*82mm - Use the company's CycloneIIEP2C5T144 ALTERA chip as the core minimum system will easily be embedded into FPGA practical application of the system. - Complete from simple logic control, data acquisition, signal processing, mathematical calculation. - Core board FPGA chip, all the leads all the pins, you can apply directly to the board into the board. 5V on the board can plug into the power supply can also be introduced through the vent array.
Hardware configuration
- EP2C5T144 FPGA chip - Configuration EPROM chip EPCS4, size 4Mbit; - 50M on board active patch crystal (crystal in the back of the board); - The power outlet with a large mouth, single 5V power supply. - The board has the power indicator light and reset switch; - Onboard 3 chip LED, LED test can do experiments, more experiments completed by lead - All through the IO port pin and clock pin leads, through these interfaces can be extended to any memory and peripherals. - Board made of high quality tantalum capacitor power supply filtering. - Support NiosII embedded CPU development.
