Delta Rostock mini G2
Main features
Print Volume: 190 x 200mm
The Layer Thickness: 0.1mm
Layer Resolution: 0.1mm
Filament Diameter: 1.75, 3mm
Print Speed: 60 to 120 mm/sec
Print Plate Size: 210 x 3mm
XYZ Bearings: carbon steel
Output:DC12V/0-15A
No. of Extruders: 1
Electronics: GT2560
Machine weight:8.5kg
Shipping box weight:9.5kg
Building instruction
For detailed building instruction, please visit here, or you can download the PDF version .
Install drivers and software
Install the drivers
here.
Macbook (OS X) Manual Install
Click "Continue" in Read me.
Click "Continue" in License.
How to set up
Media:RKMA GT2560 G2.zip
Media:RKMA GT2560 G2S.zip
How to modify and upload firmware
In the following set-up process, you will need to modify and upload the firmware by yourself, so, first of all, let’s start with the firmware comliling and uploading.
1. Download the firmware here:
Firmware for Delta Rostock mini G2
Firmware for Delta Rostock mini G2S
2. Connect GT2560 to your PC with a USB cable,install FTDI drive. Usually it will install automaticlly. If not you need to install maually.
3. If there is nothing wrong with the hardware of board, you can find COM port in device manager. But every computer has different COM watchword, you need check by yourself.
4. Unzip the firmware, drag all the files into Arduino IDE. I use Arduino1.0.5,choose Board\Arduino Mega or Mega2560,and selects ATmega2560(Mega2560) as default Processor. The order cannot be wrong. Selects the COM port you find in the device manager.
Find the value you need to comlile according to your printer. Upon compiling, you can upload the firmeare to your control board. Simply click veryfy and upload.
Printer preparing
2. To protect the bed and the nozzle from crashing, please attach a piece of tape on the bed.
Printer setting
Home X: 0,
Home Y: 0
Home Z: Max
Printer Radius: 100mm
Printable height: 200mm
Homing the printer
Homing is the first and foremostt hing you need to test. To home the printer, you can check if the three axis of the printer move in the same direction,if not, there will be crack for the spider and the carriage.
Before homing, you need to follow the next steps.
1.Go to printer setting> printer. Set the travel feed rate and the Z axis feed rate as 300 mm/min.
(Even though we have set the speed as slow as possible for you, you still need to adjust the feed rate. )
2.Hook up the probe with your hand, we are not testing the auto-leveling fuction right now.
3. Move the extruder head to the middle and be ready for emergency stop. You can click the emergency stop icon on the repetier host or shut the power supply directly.
4. Go to the Manual Control and click the home icon.
If the three axis move in the different directions, please check the conenction of the stepper motor wires.
Define the initial Z axis height
If the printer can home normally, the three axis move in the same directions, we can set the height of the Z axis now, but this value may not be the final height.
1. You can use a rule or digital graphics to measure. The height of the Z axis means the distance between the nozzle and the building platform after homing. So you need to measure after homing.
2. Or you can use maual control to move the Z axis down to the building platform till the nozzle just touches the bed. When moving the Z axis, please slow it down.
Move 0.1mm per click
3.Read the coordinates of the Z axis when the nozzle just touches the bed. E.g. if it is (0,0,1), then the Z axis height is 200-1=199。If it is (0,0,2) the height is 200-2=198.
(*200 is pre-set height in the firmware. 1 is the Z coordinate)
4. Open the firmware in IDE, locate the following code in IDE
//Manual homing switch locations:
  1. define MANUAL_HOME_POSITIONS // MANUAL_*_HOME_POS below will be used
// For deltabots this means top and center of the Cartesian print volume.
  1. define MANUAL_X_HOME_POS 0
  1. define MANUAL_Y_HOME_POS 0
  1. define MANUAL_Z_HOME_POS 200// For delta: Distance between nozzle and print surface after homing.
Then you can change the 200 into the height you got (e.g.205 or 199 you get) in the firmware and upload it.
Upon uploading the firmware, you need to change the printing setting in the Repetier host.
Home X: 0
Home Y: 0
Home Z: Max
Printable height: 205mm (* the height you put in the firmware)
Define the final Z axis height
Step1. Homeing the printer.
Step2. Tighten the screw trigger for each endstop, make sure they reach as long as possibl.
Adjust the screw on these 3 carridges.
Step3. Set 3 probing points (0,50)、(43.3,-25)、(-43.3,-25), using G-code command to adjust the print head to the 3 points and record the distance between the nozzle and the print surface separately.
3)send G 0 X-43.3 Y-25 Z2, record the distance;e.g. it is 2.2mm in my case.
You may need to adjust again and again till the three distance are the same or at least very close.
You are required to operate again and again till you get a satisfied result.
#define DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET+2.0)
  • If the nozzle touches the center point but not the around points, that is a convex surface, you should reduce the DELTA_RADIUS from 2.0 to 1.0 for example.
  • If the nozzle touches the around points but not the center point, that is a concave surface, you should increase the DELTA_RADIUS from 2.0 to 3.0 for example.
So far, we can get the exact height of the Z axis.
check the status of endstop
* x_max,y_max,z_max is for the endstop:
if the endstop is triggered, the feedback is Triggered;
If the endstop is not triggered, the feedback is Open.
z_min is for the probe:
Trouble shooting:
Define the Z_PROBE_OFFSET
//these are the offsets to the probe relative to the extruder tip (Hotend - Probe), these values are very important, especially the Z_PROBE_OFFSET.
Then modify the Z_PROBE_OFFSET in the firmware and upload again.
slic3r configuration
printer setting
1. set bed shape.
in the latest version of Slic3r,V1.2.7, you can set the bed shape, this is very important when printing with your delta rostock mini. go to general manual, click set button, choose circular and fill in the diameter of the printer bed.
  • if your slic3r is not the latest version, you can update or download it here, unzip the file and drag them into the directory of your previour slic3r directory. do please delete the old version. Restart your Repetier and continue.
2.Start G29 Command
Modify the firmware of Delta
We have pre-loaded the firmware to GT2560 before shipping, but as this is a DIY printer, there may be some subtle difference between each printer, so you need to modify the firmware to fit your exact printer for better printing effect.
1. Download the firmware here. And unzip the zip/rar file.
2. Open Arduino IDE. ( If you do not have Arduino IDE, you can download here.)
3. Drag all the files into Arduino IDE.
4. Click Configuration.h and find out Delta Settings
 #define DELTA and modify the values as below.
Please pay close attention to the red numbers.
 // Make delta curves from many straight lines (linear interpolation).
 // This is a trade-off between visible corners (not enough segments)
 // and processor overload (too many expensive sqrt calls).
 107 #define DELTA_SEGMENTS_PER_SECOND 160
 110 #define DELTA_DIAGONAL_ROD  186【1】
 113 #define DELTA_SMOOTH_ROD_OFFSET 160.0 【2】
 116 #define DELTA_EFFECTOR_OFFSET 34.0【3】
 119 #define DELTA_CARRIAGE_OFFSET 25.0【4】
* To help you better understand the 4 values, you can refer to the scheme.
 // Horizontal distance bridged by diagonal push rods when effector is centered.
 122 #define DELTA_RADIU (DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET+ 2.0)
 =160-34-25+2
 // Print surface diameter/2 minus unreachable space (avoid collisions with vertical towers).
 125 #define DELTA_PRINTABLE_RADIUS 83
 // use the Z-min, if you connect a mechanical endswitch between Com and NO pins, you do not have to change the setting for the Z-min, however, if you connect it between Com and NC pins, you should change false into true.
 322 const bool X_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
 323 const bool Y_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
 324 const bool Z_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
 325 const bool X_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
 326 const bool Y_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
 327 const bool Z_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
 // Travel limits after homing
 365 #define X_MAX_POS DELTA_PRINTABLE_RADIUS
 366 #define X_MIN_POS -DELTA_PRINTABLE_RADIUS
 367 #define Y_MAX_POS DELTA_PRINTABLE_RADIUS
 368 #define Y_MIN_POS -DELTA_PRINTABLE_RADIUS
 369 #define Z_MAX_POS MANUAL_Z_HOME_POS
 370 #define Z_MIN_POS 0
//these are the positions on the bed to do the probing,the probe positing should not be beyond the printable radius.
 382 #define DELTA_PROBABLE_RADIUS (DELTA_PRINTABLE_RADIUS*0.6)
 383 #define LEFT_PROBE_BED_POSITION -DELTA_PROBABLE_RADIUS
 384 #define RIGHT_PROBE_BED_POSITION DELTA_PROBABLE_RADIUS
 385 #define BACK_PROBE_BED_POSITION DELTA_PROBABLE_RADIUS
 386 #define FRONT_PROBE_BED_POSITION -DELTA_PROBABLE_RADIUS
//these are the offsets to the probe relative to the extruder tip (Hotend - Probe), these values are very important, especially the Z_PROBE_OFFSET. You can calculate the Z_PROBE_OFFSET values with this procedure:
Manual y Move the print head down slowly, place the probe at the center of the print bed. When you hear the trigger of the endstop, you can get the coordinate on the LCD or on the Repetier host. In my case, it is 【-20.35,11.75,0.3】, you can add it to the following settings.
 389 #define X_PROBE_OFFSET_FROM_EXTRUDER 20.35
 390 #define Y_PROBE_OFFSET_FROM_EXTRUDER -11.75
 391 #define Z_PROBE_OFFSET_FROM_EXTRUDER -0.3
 398 #define Z_RAISE_BEFORE_PROBING 100  //How much the extruder will be raised before traveling to the first probing point.
 399 #define Z_RAISE_BETWEEN_PROBINGS 10  //How much the extruder will be raised when traveling from between next probing points
 // with accurate bed leveling, the bed is sampled in a ACCURATE_BED_LEVELING_POINTSxACCURATE_BED_LEVELING_POINTS grid and least squares solution is calculated
 // Note: this feature occupies 10'206 byte
 431 #define ACCURATE_BED_LEVELING_POINTS 4
Till now, you have finished the edit of the firmware, then, you need to upload the modified firmware into your control board. For those not mentioned just leave them as default.
5.Uploard firmware Choose board type.
6.Choose serial port (if you cannot find the serial port, please check the connection of your printer to your computer.)
7.Load in the file you need to burn, Click the “” button to check if it is right and then click the “” button to upload.
8.Upon uploading, the LED indicator corresponding to the TX, RX and L on the GT2560 will blink, if they stop blinking, it means the file has been uploaded successfully.
9.After uploading, you can go on to the next step. If you cannot upload, check the dialog box below to identify the problem and solve it. The common mistakes are the wrong select of type of board or serial port etc.
Verify code
Calibration of auto-leveling
2.Send G29 command.
4.Hook up the probe manualy.
8.You may have to test it for more than once, but for the sake of better printing object,please be patient.
9.Once auto-leveling is set up, Hook up the probe manualy. Then you can print your first prints.
