Building Instructions of Geeetech Prusa I3 X
Preparation
- All the acrylic plates have been etched with part ID and the plate is covered with a sheet of kraft paper, you need to tear them off.
1. Assemble the threaded rods of Y axis
M10 nut <M10 nut < M8 spring washer<M10 washer in turn on the left
3) Thread theM10 washer < M8 spring washer < M10 nut < M10 nut< M8 spring washer < M10 washer in turn on the right
Watch the Video here.
- Tips:
You can watch the video here.
3.Mount the Y motor
Fix the holder plate with 2 M3 x 16 screws and M3 square nut.
- be careful in case the Acrylic break down.
4.Y belt driving wheel
Step1. Thread the M3 x 20 screw through the bearing holder.
Step2. Put the M4 x25 screw through the holes with the two 624ZZ bearings in between. Lock the other end with a M4 lock nut. You may need a spanner to tighten locking nut.
- Please leave enough room for the belt between the ball bearing and the screw.
5. Build the print platform
6. Mount the Y belt
- Tips:
1. Before you drill your second hole, make sure to pull belt tightly to make sure to proper placement of hole for a tight belt, if it is too loose, it will hinder the move of the print platform.
2. Loosen the Y idler wing nut when tightening belt onto the Y belt mount [No. 67] in order to make securing the belt to the block easier. Be sure to tighten wing nut fully once done.
Watch the video here.
7.Left Z motor mount
Step 1. Mount the endstop on the endstop mount with two M2.5 x 16screws and nut.
8.Right Z motor mount
Assemble the motor holder ((right) and the motor holder support together, screw it up with 3 M3 x 16mm screw and M3 Square nut.
10.Side panel assembly
11.Main frame assembly
Step 1. Thread the assembled Y axis into the main frame(A1), put the main frame between the Connecting fender and the M10 nut. The Connecting fender is at the front part of the Y axis. Step 2. Connect the side panel to the rear support plate, screw it up with M3 x 16mm screw and M3 square nut. Step 3. Fix the connecting fender to A1 with M3 x 20mm screw and M3 hex nut.
12.Fan mount
Mount the fan on the left side of the A1. Watch the video here.
Step 1. Mount the Z-axis nut.
Mount the Z nut on the A 18 from bottom to up, fix with M3 x 16mm screw and M3 washer.
Step 3. Mount the endstop
- Note the direction
Mount the X motor
Mount the Z motor
17. X belt driving wheel
Add the belt
- Tips:
DO NOT rush to drill the second hole now, we are not sure about the length of the belt needed untill we assemble the X axis on the printer.
19. Assemble the X axis on the printer
23.Mount the LCD panel
EXP 1 is for the SD card reader. EXP 2 is for the displaying of the LCD.
Do not mix them up.
Here you can watch the video.
25.Mount the control board.
Here is the video.
26.Wiring
GT2560 Before you start wiring, please take a look at the wiring schematics.
4) Connect Extruder motors
Connect extruder 1.
Step4. Connect heating wires.
- There is no “+” and “-“ polarityfor heating wires
Step7. Connect wires for Fan.
If you use the 2-pin extension wire for the fan, just plug them on the + and - pin.
EXP1 to SD card
EXP2 to LCD
Brown------L
Blue ------N
Yellow------GND
Red ------ -- + V
Black------COM
27.Mount the filament spool.
Each machine may have its own calibration procedure and this manual will not attempt to cover all the variations. Instead here is a list of key points that should be addressed. Frame is stable and correctly aligned. Belts are taut. Bed is level in relation to the path of the extruder. Filament rolls freely from the spool, without causing too much tension on the extruder.
Current for stepper motors is set to the correct level.
Firmware settings are correct including: axis movement speeds and acceleration; temperature control; end-stops; motor directions.
Extruder is calibrated in the firmware with the correct steps per mm of filament.
The point regarding the extruder step rate is vital. Slic3r expects that the machine will accurately produce a set amount of filament when told to do so. Too much will result in blobs and other imperfections in the print. Too little will result in gaps and poor inter-layer adhesion. For how to set up the printer, please visit:https://www.youtube.com/playlist?list=PLODCkot3GriiNbAxIwO9JCZjQSb92CWN7
