Prusa I3 X
Geeetech Prusa I3 X is a new member of the prestigious Prusa I3 family, it was engineered to provide redefined usability, quality, performance and most important, best affordability in desktop 3D printer market. The Geeetech Prusa I3 X is made from piano-black laser-cut acrylic frame. To maintain the garage-built feel and the handmade charm, Geeetech Prusa I3 X is also a DIY kit, which provide you an unforgettable step-by-step learning experience of 3D printer from scratch. Geeetech Prusa I3 X has a wide range of customers , young or old, professional or amateur, as long as you have a passion for creativity, you can not afford to miss our Prusa I3 X.
- Multiple 3D printing filament supportable: PLA,ABS, Wood-Polymer, Nylon, flexible PLA and PVA.
- Switchable from dual extruder to single extruder, generating multiple printing effect.
- 200x200x170mm printing volume, just right for you.
- 0.05mm printing precision.
- 8-mm-thick laser cut acrylic frame for rigidity and long life.
- Stainless steel rail rods, gears, bearings and connectors for smoother movement.
- All metal pulleys for improved functionality and performance.
- Super-flat aluminum alloy print surface for better adherence.
- Quick-release feed gears for faster and fluent filament feeding.
- filament size: 1.75mm.
- Custom nozzles in 5 sizes: 0.30mm, .35mm.
Printing specifications:
Build volume: 200 x200x140mm
Layer resolution: 0.05-0.3mm
Filament diameter: 1.75mm
Software:
File format: .STL, G-code
Temperature:
Electrical:
Power supply:
Output:DC12V/0-20A
Mechanical:
Physical Dimensions & Weight:
Net weight: 8.7kg
Shipping weight: 10kg
Assembly
Click this:[1]
Install the drivers
Windows 8
Windows Manual Install
Macbook (OS X) Manual Install
How To set up
How to Connect 1. Plug the USB into your Prusa I3 and the other end into your computer.
3. Open Repetier Host and ensure that you have a valid port selected for communications. To do this simply, click “Printer Settings” in the upper right-hand corner to bring up the printer settings menu.
4, Select GEEEtech PI3A in “Printer”
5. Select the corresponding COM port, click OK to continue.
In Mac, you should finish step 5 in "Printer>Printer settings", step 4 is unnecessary
6. Hit "connect" in the upper left-hand corner, select GEEEtech PI3A. You should see the details of the connection in the console window in the bottom section of the screen. if your pronter is other models, you can select it, if you are not sure, you can skip it and connect directly.
7. On the right panel, click the "Manual Control" tab. Scroll down and click both heat extruder and heat print bed buttons to activate your heaters. You will know they are on if they turn a bright blue.
8. At the same time, you can click the arrows on the above panel to move the motors to check if they work well.
9. Click “load” to load the STL. File you need to print.
10. After loading, choose “slicer” > “configure” to set the printing configurations. You may need to wait for a minute.
11. First, you need to set the layers and perimeters. As you can see in the following picture, all you need to set is the layer height and the first layer height. Leave the rest as default. (For each setting, you can get a prompt to refer)
12. Set the printing infill density and pattern. Refer to the prompt.
13. Set the printing speed. Again, refer to the prompt.
14. Filament setting. You just need to fill in the correct filament diameter.
15. After setting, do not forget to save the settings and name each setting.
16. Select the settings you save on the right panel. Then click the “Slice with slice3r”to generate G- code. You may have to wait for a while.
17 click slicer button and slice with Slic3r.
- Here is a temp reference.
Filament Type Bed temp Extruder temp PLA 50-100 190-210 ABS 70-110 220-240
Leveling The Print Bed
Belt Tensioning
Tools:
2.5 mm hex driver
1.5 mm hex driver
Steps
How to control on LCD
1.How to print from LCD
- Press the button>”Prepare”>”Move axis”>”Move 10mm/1mm/0.1mm”>”Move X/Y/Z/extruder”>Rotate the button> Press button
Slic3r Manual
FAQs & SOLUTIONs
