Geeetech prusa i3 pro C building instruction
Notice:
Unfold and check the package
Tips:
Assemble the rods of a Y axis
| Required parts | Required number | Part ID |
Assemble the Y idler
Mount the Y motor
Build the printing platform
Step4. Mount the belt.
Assemble Y - Z axis
Mount the fan
Assemble the 2 Z motors
Assemble the smooth rods
Assemble the X-Axis end
Mount the extruder holder
Mount the extruder
mount the fan for extruder
Mount the X-axis motor
Amount the X-axis belt
Assemble the X-Z axis
Attach he heated bed
Mount the end stops
Step 1.End stop of X-axis
Step2. End stop of Y-axis
Step3. End stop of Z-axis
Mount the LCD panel frame
Mount the PSU
Example 1: Sanguinololu
Example 2: Ramps 1.4
Wiring
3.Connect the heatbed.
4.Connect the extruder
5.Connect the end stops.
6.Connect the power supply.
Mount the board
Mount the filament spool
