GT2560
1.Integrated with the mighty function of the Arduino Mega2560+Ultimaker, The GT2560 can not only take full place the Arduino Mega2560+Ultimaker on respect of both software and hardware, but also features compact size, more convenient connection, and more stable.
3. The power pack: operating voltage is 12V-24V; double power supply design feeds for heatbed and logical part separately. The current is 12A for heatbed and 5A for other parts. The cooling fan can support 12V
(front and back images)
Hardware resources:
3 input for12V cooling fan
1 PWM output
Weight: 80 g
Software Resources
Firmware: Marlin
Host software:printrun Repetier-Host
Source
Interface specifications
1.DC IN: 12V 12A and 12V 5A
2.HOT_BED: heat bed
5.LCD ENCODER: LCD panel
6.SD Card
11. X,Y,Z:Stepper motors for X, Y, Z axis(XH2.54-2 pin)
12. EXT1, EXT2(A):Stepper motors for extruder 1 and extruder 2(XH2.54-2 pin)
13. FAN1,FAN2,FAN3:3 12V cooling fans(XH2.54-2 pin)
The subdivision of stepper motor can be setup by dial switch, turn on all the dial switch, as the arrow shows
Software setting
File Burning
firmware, as shown below.
Get Started
#define BAUDRATE 250000
#define MOTHERBOARD 7
#define EXTRUDE_MINTEMP 170
- At most 2 extruders, GT2560 supports 5 A4988 stepper motor drivers, they are X/Y/Z axis and 3 extruders.
2. What is the Power Requirement of GT2560?
- It is 12V 12A for the heatbed and 12V 5A for the logical part.
How to get
Visit here now!
