Sanguinololu
Revision as of 07:52, 21 August 2014 by Admin (talk | contribs) (file)
Features: 1.support multiple communication configurations :
3.Adapts Atmel's ATmega644P - ATmega1284 drop-in compatible. Currently, we use 1284P, the bootloader has been burned before shipping, and users can put it into use after burning the programming code.
  • Removed the Molex HDD connector in favor of using the voltage regulator - some power supplies give a dirty 5V signal when there is no motherboard load, so its better to just use the power supply's ATX+4 connector and the 5V voltage regulator.
  • Added a jumper to enable/disable USB auto-reset. This way if you're printing from an SD card using SDSL you can disconnect your USB and reconnect it without interrupting a print.
  • R7 and R8 are now 100k pull-up resistors that are on the stepper-enable lines. This ensures the stepper motors stay disabled and don't move while uploading new firmware, rebooting, etc. The current limiting resistors for the FTDI are gone.
  • There is an extra Z-motor header for Prusa Mendel.
size:100mm x 60mm
weight:73g
Software Resources
Pc software:
Sanguinololu drive: http://www.geeetech.com/wiki/index.php/Sanguinololu
Interface specifications
  • 2 ADC interfaces for thermometry: one for extruder and another for hotbed.
  • 3 PWM to control extruder, hotbed and fan.
  • 3 end stops for x/y/z axis( mechanical, optical or hall sensor)
  • The USB 5V VBUS is connected to the output of the 5V regulator. This is bad for the regulator and bad for the PC. Some users report the regulator getting very hot (because it is trying to power the PC), other users report the PC giving USB over current errors. Nophead and Nothinman recommend cutting the 5V track to the USB connector. The only downside is the board needs the 12V supply before it will do anything, but who cares?
  • When the bootstrap loader runs during reset and when downloading firmware the motors are enabled due to pull-downs on the Pololus (The enable pins are pulled up by 100K resistors on the Sanguinololu but they are pulled down by 100K on each Pololu). The step pins are floating and this can cause random motor movements. The E step pin is next to E dir pin which the bootstrap thinks is an LED to be flashed. Crosstalk can cause the extruder to spin when firmware is being loaded. This is not good as it will be cold, so could damage the hot end. Nophead recommends changing the enable line pull ups (R7 and R8) to 4K7 to ensure the motors are disabled until the firmware enables them.
  • The pads and traces on the board are not robust enough to handle the high current involved when controlling the heated bed with the sanguinololu's dedicated mosfet. If left as is, the board will heat up in this area, could be damaged and the plastic connectors discolored. To fix, simply add a direct current path by way of (preferably insulated) wire from the 12v input to the 12v pins on the Heated Bed (HB) connector; from the center pin of the HB mosfet to the two ground pins on the HB connector; and from the ground pin on the mosfet to the ground input of the board (probably the ground side of the 12v connector). Find the appropriate traces using continuity check or resistance mode on your multimeter, and check after to ensure you didn't create a short between any of these components in the process. It would be prudent to check for shorts before starting so you don't waste effort trying to fix a short you think you just created but was already there before you applied this fix. To understand this fix, pretend that no traces exist between the high current pathways of the 12v input and 12v pins of the HB connector; the ground input and the ground pin on the mosfet, and the center pin of the mosfet and ground pins on the HB connector. Assume you must create these pathways, then do so!
Jumper Instruction=
jumper       Yes/No     stepsize
ms1     ms2      ms3
no      no       no     fullstep
yes     no       no     halfstep
no      yes      no     1/4step
yes     yes      no     1/8step
yes     yes      yes    1/16step
jumper   Yes/No       step size
ms1     ms2      ms3
no      no       no    full step
yes     no       no    half step
no      yes      no    1/4 step
yes     yes      no    1/4 step
no      no       yes   1/16 step
yes     no       yes   1/32 step
no     yes    yes      1/32step
yes    yes    yes      1/32step
File Burning
Click the check“ File:Button 1.jpg” button to check if it is right and then click the “ ” button to upload firmware, as shown below.
file
Media:Sanguino-0101r1.zip
Media:Sanguinolu.zip
Media:arduino--0023.zip
Media:Sanguino_sch.rar
firmware download
