Sanguinololu
1.support multiple communication configurations :
3.Adapts Atmel's ATmega644P - ATmega1284 drop-in compatible. Currently, we use 1284P, the bootloader has been burned before shipping, and users can put it into use after burning the programming code.
size:100mm x 60mm
weight:73g
Software Resources
Pc software:
Bugs
file
firmware download
