GPRS Shield V2.0
Hook your Arduino up to GSM/GPRS cell phone network with GPRS shield! You can use your Arduino to dial a phone number or send a text to your friend via easy to use AT commands now. This new version features a quad-band low power consumption GSM/GPRS module SIM900 as well as a compact PCB antenna. Meanwhile, improvements on interfaces and basic circuit have been taken to make it more concise and reliable. Check out the improvement details of V2.0.
Model:SLD01098P
- Compatible with standard Arduino and Arduino Mega
- Selectable interface between hardware serial port and software serial port
- Quad band support: 850/900/1800/1900MHz
- Support TCP/UDP protocols
- Full control via AT commands set: Standard - GSM 07.07 & 07.05 and Enhanced - SIMCOM AT Commands
- 2-in-1 headset jack
- Convenient external SIM card holder
- Low power consumption: 1.5mA(sleep mode)
- 3V CR1220 Battery Holder Connetor
Cautions
- GPRS Shield doesn't come with ESD precautions. Take special care when handling it in dry weather.
Interface Function
Antenna interface: external antenna could be added here for expansion
Serial port select: select either software serial port or hardware serial port as interface with Arduino
Hardware Serial: D0 and D1 of Arduino/Seeeduino
Software serial: D7 and D8 of Arduino/Seeeduino only
Status indicator: tell whether SIM900 is on
Power-on indicator: tell whether the GPRS Shield is on
Net indicator: tell the status about SIM900 linking to the net
GPIO,PWM and ADC of SIM900: GPIO,PWM and ADC pins breakout of SIM900
Headsets interface: mic and earphone 2-in-1 interface
Power button: turn on or off SIM900
Pins usage on Arduino
D0: Used as RX of hardware serial port
D1: Used as TX of hardware serial port
D7: Used as RX of software serial port
D8: Used as TX of software serial port
D9: Used as software power button for SIM900
VIN: Used if you select external 6.5V~12Vpower supply for the Arduino and GPRS Shield
LED Status Description
LED | Status | Function |
Power-on indicator(Green) | Off | Power of GPRS Shield is off |
On | Power of GPRS Shield is on | |
Status Indicator(Red) | Off | Power off |
On | Power on | |
Net indicator(Green) | Off | SIM900 is not working |
64ms On/800ms Off | SIM900 does not find the network | |
64ms On/3000ms Off | SIM900 finds the network | |
64ms On/300ms Off | GPRS communication |
As you receive the GPRS Shield, what would be the first thing you want to do with it? Send out a text (SMS)? Or call up someone (headset required)? You can do all of this by talking to the GPRS Shield using AT Commands - a special language that it understands.
Hardware Installation
Follow the steps below to set up the hardware system.
1. Insert an unlocked SIM card to SIM Card Holder
A 6 Pin Holder for SIM Cards. Both 1.8 volts and 3.0 volts SIM Cards are supported by SIM900, the SIM card voltage type is automatically detected.
2. Check the antenna
Make sure the antenna have installed properly in the antenna interface.
Communication port configuration
The GPRS shield can be controlled via hardware serial port or software serial port of Arduino. Here we use the software serial port as default. Choose it by inserting jumper caps as below.
4. Plug to Arduino
Stack the GPRS Shield onto Arduino.
5. Power up Arduino
Power up Arduino by USB cable or DC Jack. The Power-on indicator LED should light up once connectted.
Fun with AT Commands
Step 0: Basic tutorial
AT+SGPIO=OPERATION, GPIO#, FUNCTION, LEVEL
OPERATION
- 0 = Set GPIO to output or keypad
- 1 = Read GPIO level (Funtion MUST be set to input ( 0 )
GPIO# SET to the GPIO pin number for the command 1=12
FUNCTION
- 0 = Set GPIO to INPUT
- 1 = Set GPIO to OUTPUT
- 2 = Set GPIO to KEYPAD
LEVEL
0 = Set GPIO to LOW 1 = Set GPIO to HIGH
Example: To set level of GPIO pin 3 HIGH (on);
AT+SGPIO=0,3,1,1
Delete all SMS messages in memory; YourSerialName.println("AT+CMGD=1,4\r"); Read a SMS in index # 1; YourSerialName.println("AT+CMGR=2\r"); Read list of SMS messages in memory; YourSerialName.println("AT+CMGL=\""ALL\"'); Send a SMS message with text in a variable called newMsg; YourSerialName.print("AT+CMGF=1\r"); delay(500); YourSerialName.println("AT+CMGS=\"+17065551212\""); delay(1500); YourSerialName.println(newMsg); or YourSerialName.println("Hello World"); delay(100); GPRS.println((char)26); // End AT command with a ^Z, ASCII code 26
Hope this is helpful to others who are enjoying this shield.
Let's have a try to control the GPRS shield with AT commands.
The GPRS Shield comes with all accessories that you need to get started with sending data over the GSM network except an Arduino board and a GSM SIM Card. If you want to make voice calls, you would also require a headset with microphone.
Step 1: Test Setup
1.Create a new Arduino sketch and paste the codes below to it.
2. Upload the code to Arduino. If you do not know how to upload the code, please click here.
3. Download and fire up serial tool if you don't have one. Choose the correct COM port for Arduino, and set it to operate at 19200 8-N-1 and then click "Open Com". You can also use AT Command Tester to send AT commands. Please click here if you are interesting in it.
4. Power up the SIM900 by pressing the power button in about 2 seconds. The red LED will be on. The green one beside it will blink. If the shield join the network sucessfully, the green LED will blink every 3 seconds.
5. You should find the message on the serial monitor as below which is sent by the SIM900 to inform you it has joined the network:
RDY +CFUN: 1 +CPIN: READY Call Ready
Notice: How AT commands control the GPRS Shield
The ATmega328P microcontroller on Duemilanove board has only one UART which is used for communicating with the PC. What we need is an Arduino Sketch running inside the ATmega328P that would emulate a second serial port (UART) using software on the digital pins D8 and D7 and patch through all the communication between this second software serial port and the actual hardware serial port. By doing this, all the data coming from the computer (connected to the actual hardware UART) would be routed to the GPRS Shield (connected to software UART) then, we would be able to issue AT commands to control the GPRS Shield. The block diagram outlining this scheme is shown below.
Step 2: Send A Text Message(SMS)
Based on step 1, now we try to send a text message by using AT commands.
- The GPRS Shield can send SMSes in two modes: Text mode and PDU (or binary) mode. To send out a human readable message, select the text mode by sending AT command "AT+CMGF=1". If succeeds, The GPRS Shield will respond with an OK.
- To enter the number of your target phone, tick "SendNew" option and send AT+CMGS="136*****556". This will instruct the GPRS Shield to send a new message to the phone number specified (replace the number with the phone number of your target phone). The GPRS Shield will send a> to remind you of typing the message. Please note that phone number specified as parameter in any AT command must be in E.123 format.
- After entering your message, tick "send hex" option and then send a hex: 1A. The modem will accept the message and respond with an OK. A few moments later, the message should be received on the handset whose number you had specified. I sent "How are you ?". You can check the histroy by clicking "EXT". The commands histroy is listed below "Set Multi Char".
NOTE: If, in spite of following the steps as specified above, you're unable to receive the message on the target handset, you might need to set the SMS Message Center number. Send the following command between the AT+CMGF and AT+CMGS commands:AT+CSCA="+919032055002". Replace the phone number specified with the SMS Center number of your GSM Service Provider. The message center number is specific to each service provider. You can get the message center number by calling up the customer care center of the GSM Service Provider and asking them for it.
Step 3: Make a telephone call with the AT commands
- Restart the SIM900 if switching from sending texts to making phone calls.
- Replace the phone number with your target number in the command “ATD186*****308;”(without the quotes) and press Enter key to send it out. If it succeds, a message "ATH OK" will show up as the picture below. Otherwise, "No CRRLIER" will show up instead. The reason might be unexistent phone number or incorrect command format.
Step 4: Exploring Further
Now that you have gotten a taste of how the AT Commands work, you can try out some more of them by moving on to developing sketches for Arduino to use the GPRS Shield. This involves creating a sketch to send out a sequence of AT Commands to the GPRS Shield to perform tasks as sending an SMS, making a call or sending data over a GPRS connection. You can go through the AT Commands reference manual to figure out the sequence of commands required to do a particular task. If while developing an Arduino sketch, you find that the GPRS Shield doesn't execute what you have expected, check the AT Commands you sent to find out whether the spelling or sequence gets wrong. To do this, reload the serial relay sketch attached above in step 1 and type out the AT Commands manually and check the output. The responses sent by the GPRS Shield will help you debug the AT Command sequence.
A Simple Source Code Examples for phone calls and sending text messages
The demo code below is for the Xduino to send SMS message/dial a voice call. It has been tested on Arduino Duemilanove but will work on any compatible variant. Please note that this sketch uses the software UART of ATmega328P. So follow the steps below for running this sketch.
1. Follow the hardware installation steps to set up the hardware system.
2. Create an Arduino project and paste the program below to it. Replace the following items in the code:
- 1) Phone number. Replace the number “+86186*****308”(+86:China code) with the phone number of the target phone, don't forget add the country code.
- 2) The content of the message. Change the content “How are you ?” to what you want to send.
/*Note: this code is a demo for how to using GPRS Shield to send SMS message and dial a voice call. The microcontrollers Digital Pin 7 and hence allow unhindered communication with GPRS Shield using SoftSerial Library. IDE: Arduino 1.0 or later */ #include <SoftwareSerial.h> #include <String.h> SoftwareSerial mySerial(7,8); void setup() { mySerial.begin(19200); // the GPRS baud rate Serial.begin(19200); // the GPRS baud rate delay(500); } void loop() { //after start up the program, you can using terminal to connect the serial of gprs shield, //if you input 't' in the terminal, the program will execute SendTextMessage(), it will show how to send a sms message, //if input 'd' in the terminal, it will execute DialVoiceCall(), etc. if (Serial.available()) switch(Serial.read()) { case 't': SendTextMessage(); break; case 'd': DialVoiceCall(); break; } if (mySerial.available()) Serial.write(mySerial.read()); } ///SendTextMessage() ///this function is to send a sms message void SendTextMessage() { mySerial.print("AT+CMGF=1\r"); //Because we want to send the SMS in text mode delay(100); mySerial.println("AT + CMGS = \"+86186*****308\"");//send sms message, be careful need to add a country code before the cellphone number delay(100); mySerial.println("How are you ?");//the content of the message delay(100); mySerial.println((char)26);//the ASCII code of the ctrl+z is 26 delay(100); mySerial.println(); } ///DialVoiceCall ///this function is to dial a voice call void DialVoiceCall() { mySerial.println("ATD + +86186*****308;");//dial the number delay(100); mySerial.println(); } void ShowSerialData() { while(mySerial.available()!=0) Serial.write(mySerial.read()); }
3. Upload the code. If you input't', your GPRS shield will send a SMS message to the target cellphone. If you input'd', the program will dial a call to the target cell phone.
4. If the program returns error in the terminal after you typed the command, don't worry, just try input the command again.
Improvement Details of GPRS Shield V2.0
Appearance Change
1) V2.0 adopts a standard shield outline as well as a protective shell;
2) Duck antenna is replaced by a compact PCB antenna;
3) Mic and earphone interfaces are replaced by 2-in-1 headset jack on V2.0.
Power Circuitry Change
Replace the original LDO circuitry with DC-DC circuitry. Heat dissipation gets lower and efficiency gets higher up to 80%+. Meanwhile, the EXT_PWR jack on V1.0 was removed. V2.0 can draw current directly from Arduino now without additional 5V adapter.
Soft Start Circuitry
Soft start circuitry is added in the new version to smooth out the power shock at the moment the shield turns on, preventing the shield from unexpected reset issue.
Below is how power shock affects the 5V pin of Arduino:
The blue line is the 5V signal from Arduino and the yellow is the power pin of GPRS shield V1.0. The blue line drops significantly down to 1.08V at the moment the GPRS shield turns on, which finally results in a system reset because it outlasts 3ms.
The same process on the new version:
This time the power-on only causes a pulse in small magnitude. No reset turns up because the pulse only lasts about 1us.
Next let's have a look at the startup situation of the soft start circuitry. The red line below represents the wire between the Q5 and D2:
The signal is relativly flat. There are about 2.5s charging time for GPRS shield. In this time scale, there is no noticable shake of the 5V signal of Arduino.
Antenna Revision
The maximum transit power of SIM900 is 30dBm(1w). However the output power of V1.0 is only 0.4W. In this new version, transit power is turned up to 29dBm above(0.8w+), giving you more reliable and firm signal transmission.
instructions to test the communication
If you are using a Router rather than a modem or Exchanger, before networking testing for the GPRS module, you should pay attention to the following tips.
1. Specify a fixed IP address for Local Host,hereinafter referred to as "Local Host IP".
2. Set a Port Mapping on the Router and map the port to Local Host IP. We call the set port "Local Host Port". Local Host Port is within 0 and 65535.
3. Open home page (Google), input "IP" to check your Public IP.
FAQS
Q1. Why should I specify a "Local Host Port" on the Router (Port Mapping)?
ADSL dials through a router and the host shares network through the router. In this case, the host usually extracts Private IP such as 192.168.x.x. for such reasons, only when you specify a ‘Local Host Port’ on the Router (Port Mapping) and forward it to the corresponding Local Host, can the Internet access to the Local Host through this Port.
Q2. Why should I specify a Fixed Private IP for the Local Host?
Port Mapping is a one-to-one process. If the Local Host is specified to obtain IP automatically, the IP address will probably change when the computer restarts or reconnects to the network. Therefore, it is necessary to specify a Fixed Private IP.
Tools
1. Arduino IDE
2. Net Assist
3. STC-SIP
Steps
1, Start the "Net Assist", choose "TCP server" in the dropdown menus of "protocol" (UDP Server is not recommended), change the "Local Host IP" into the Fixed IP. Input the "Local host port" set before and then click “Connect “. As shown in following the picture.
Input the following code in the text box of "TX Buffer" and then press "Enter".
AT+CLPORT="TCP","2022"
Click "Send Data". If the "RX Buffer" shows "ok", it is successful.
OK
Input in "TX Buffer" as follows,
OK CONNECT OK
AT+CIPSEND
in "TX Buffer", then press "Enter". Click "Send Data" and the "RX Buffer" appears
as follows.
Input
HELLO WORLD
in "TX Buffer" and click "Send Data", check "HEX-Mode".
Meanwhile, input
1A
to end instruction and click "Send Data". It is successful when you see
SEND OK
Now,"Helloword" will appear in "NetAssist".
PS:
Media:For gprs networking test.rar
HOW TO BUY
Click here to buy GPRS Shield V2.0
