Arduino GPRS Shield
Revision as of 13:41, 7 July 2014 by Admin (talk | contribs) (→Tools)
  • GPRS multi-slot class 10/8
  • GPRS mobile station class B
  • Compliant to GSM phase 2/2+
  • RTC supported.
  • Selectable serial port.
  • Speaker and Headphone jacks
Application Ideas
Cautions
Hardware Diagram
  • Power select - select the power supply for GPRS shield(external power or 5v of arduino)
  • Power jack - connected to external 4.8~5VDC power supply
  • Antenna interface - connected to external antenna
  • Serial port select - select either software serial port or hareware serial port to be connected to GPRS Shield
  • Hardware Serial - D0/D1 of Arduino
  • Software serial - D7/D8 of Arduino
  • Status LED - tell whether the power of SIM900 is on
  • Net light - tell the status about SIM900 linking to the net
  • UART of SIM900 - UART pins breakout of SIM900
  • Microphone - to answer the phone call
  • Speaker - to answer the phone call
  • GPIO,PWM and ADC of SIM900 - GPIO,PWM and ADC pins breakout of SIM900
  • Power key - power up and down for SIM900
  • Pins usage on Arduino
  • D0 - Unused if you select software serial port to communicate with GPRS Shield
  • D1 - Unused if you select software serial port to communicate with GPRS Shield
  • D2 - Unused
  • D3 - Unused
  • D4 - Unused
  • D5 - Unused
  • D6 - Unused
  • D7 - Used if you select software serial port to communicate with GPRS Shield
  • D8 - Used if you select software serial port to communicate with GPRS Shield
  • D9 - Used for software control the power up or down of the SIM900
  • D10 - Unused
  • D11 - Unused
  • D12 - Unused
  • D13 - Unused
  • D14(A0) - Unused
  • D15(A1) - Unused
  • D16(A2) - Unused
  • D17(A3) - Unused
  • D18(A4) - Unused
  • D19(A5) - Unused
  • Note: A4 and A5 are connected to the I2C pins on the SIM900. The SIM900 however cannot be accessed via the I2C .
Getting Started
  • Insert a unlock SIM card
  • Make sure the antenna pad buckled properly
  • Assemble the GSM antenna
  • Chooose communication port properly using the jumpers
  • Assemble GPRS shield to Arduino and download the sketch
  • Press power key about 2 seconds to turn on the GPRS shield
Indicator LEDs
Power Up the GPRS Shield
void powerUp()
 pinMode(9, OUTPUT);
 digitalWrite(9,LOW);
 delay(1000);
 digitalWrite(9,HIGH);
 delay(2000);
 delay(3000);
void powerDown()
 pinMode(9, OUTPUT);
 delay(1000);
 delay(2000);
 delay(3000);
UNDER-VOLTAGE WARNNING
OVER-VOLTAGE WARNNING
UNDER-VOLTAGE POWER DOWN
OVER-VOLTAGE POWER DOWN
+CMTE:1
+CMTE:-1
+CMTE:2
+CMTE:-2
  • Not all Arduino boards support software serial on D7 and D8, For example Arduino Mega and Mega 2560 only support the following pins for RX: 10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69. So Arduino Mega doesn't support soft serial on Pin D7 and D8. If using GPRS shield with Ardiuno Mega, please use the hardware serial or use the jumper wires wiring GPRS TX and RX to the pins support interrupt on Ardiuno Mega. And not all pins on the Leonardo support change interrupts, so only the following can be used for RX: 8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI). More information about Softserial library please visit http://arduino.cc/en/Reference/SoftwareSerial
Upload Sketch to Arduino
  1. Follow the previously described hardware installation steps to set up the hardware system;
  2. Make sure the GPRS_TX & GPRS_RX jumpers on the GPRS Shield are mounted in SWSerial position - that is we want GPRS_TX to be connected to D7(RX) and GPRS_RX to D8(TX).
  3. Connect the Arduino Duemilanove to your computer using a USB cable.
  4. The ATmega328P microcontroller on Duemilanove board has only one UART which is used for communicating with the PC. What we need is an Arduino Sketch running inside the ATmega328P that would emulate a second serial port (UART) using software on the digital pins D8 and D7 and patch through all the communication between this second software serial port and the actual hardware serial port. By doing this, all the data coming from the computer (connected to the actual hardware UART) would be routed to the GPRS Shield (connected to software UART) then, we would be able to issue AT commands to control the GPRS Shield. The block diagram outlining this scheme is shown below.
//at 19200 bps 8-N-1
#include <SoftwareSerial.h>
SoftwareSerial GPRS(7, 8);
int count=0;     // counter for buffer array
 GPRS.begin(19200);               // the GPRS baud rate
 Serial.begin(19200);             // the Serial port of Arduino baud rate.
 if (GPRS.available())              // if date is comming from softwareserial port ==> data is comming from gprs shield
   while(GPRS.available())          // reading data into char array
     buffer[count++]=GPRS.read();     // writing data into array
     if(count == 64)break;
   Serial.write(buffer,count);            // if no data transmission ends, write buffer to hardware serial port
   clearBufferArray();              // call clearBufferArray function to clear the storaged data from the array
   count = 0;                       // set counter of while loop to zero
 if (Serial.available())            // if data is available on hardwareserial port ==> data is comming from PC or notebook
   GPRS.write(Serial.read());       // write it to the GPRS shield
void clearBufferArray()              // function to clear buffer array
 for (int i=0; i<count;i++)
   { buffer[i]=NULL;}                  // clear all index of array with command NULL
  1. .Upload the sketch to the Arduino board.
  2. .Download and fire up serial tool if you don't have one. Choose the correct COM port for Arduino, and set it to operate at 19200 8-N-1 and then click "Open Com".
  3. .You can power on or off the the SIM900 by pressing the button about 2 second. After power on, the red LED will be on, and the green one beside it will blink and the shield has found the net if it blinks every 3 seconds.
+CFUN: 1
+CPIN: READY
Call Ready
  • Step 2: Sending a text message (SMS)
  1. .Create the setup as described in Step 1 above.
  2. .Through your serial terminal software, send AT+CMGF=1 and press the Enter key. The GPRS Shield can send SMSes in two modes: Text mode and PDU (or binary) mode. Since we want to send out a human readable message, we will select the text mode. The GPRS Shield will respond with an OK.
  3. .Click "send new" option and send AT+CMGS="+918446043032". This will instruct the GPRS Shield to start accepting text for a new message meant for the phone number specified (replace the number with the phone number of the target phone). The GPRS Shield will send a > to remind you typing the message.
  1. .Start typing your message and when you are done, and click "send hex" option and then send a hex: 1A. The modem will accept the message and respond with an OK. A few moments later, the message should be received on the handset whose number you had specified.You can refer to the picture below.
SoftwareSerial library Notes
A Simple Source Code Examples
  1. .With the GPRS Shield removed, download this sketch into your Arduino.
  2. .Disconnect the Xduino from USB port to remove power source.
  3. .Set the Serial Port jumpers on the GPRS Shield in SWserial position, to use the Soft Serial port of Arduino.
  4. .Connect the antenna to the GPRS Shield and insert the SIM Card.
  5. .Mount the GPRS Shield on Arduino.
  6. .Connect the Arduino to the computer by USB, and fire up your favorite serial terminal software on computer, choose the COM port for Arduino, set it to operate at 19200 8-N-1.
  7. .Type command in the terminal to execute different function, threr are 4 functions in the demo:
    1. .If you input 't', the demo will send a SMS message to another cellphone which you set(you need set the number in the code);
    2. .If you input 'd', the program will dial a call to the other cellphone that you set(it is also need you set in the code );
    3. .If you input 'h', it will submit a http request to a web that you want to access(it need you set the web adress in the code), it will return a string from the website if it goes correctly;
    4. .If you input 's', it will upload the datas to the pachube(for detail you can refer to the explanation in the code). I strongly recommend you input 'h' before input 's', because uploading datas to the pachube need do some setting, after execute the function of submit a http request, the setting will be set.
  8. .If the program returns error in the terminal after you typed the command, don't worry, just try input the command again.
 IDE: Arduino 1.0 or later
 to your account at cosm.com
#include <String.h>
 delay(500);
   switch(Serial.read())
    case 't':
      SendTextMessage();
      break;
    case 'r':
      DialVoiceCall();
      break;
    case 'd':
      DialVoiceCall();
      break;
    case 'h':
      SubmitHttpRequest();
      break;
    case 's':
      Send2Pachube();
      break;
 if (mySerial.available())
///SendTextMessage()
 void SendTextMessage()
 delay(100);
 delay(100);
 delay(100);
 delay(100);
 mySerial.println();
 void RecieveTextMessage()
 //delay(100);
   delay(100);
   delay(100);
   delay(100);
   delay(100);
   mySerial.println();
 //return r;
///DialVoiceCall
void DialVoiceCall()
 delay(100);
 mySerial.println();
///SubmitHttpRequest()
void SubmitHttpRequest()
 mySerial.println("AT+CSQ");
 delay(100);
 delay(100);
 ShowSerialData();
 delay(1000);
 ShowSerialData();
 delay(4000);
 ShowSerialData();
 delay(2000);
 ShowSerialData();
 delay(2000);
 ShowSerialData();
 delay(1000);
 ShowSerialData();
 ShowSerialData();
 delay(300);
 ShowSerialData();
 mySerial.println("");
 delay(100);
///send2Pachube()///
void Send2Pachube()
 delay(100);
 ShowSerialData();
 delay(1000);
 ShowSerialData();
 delay(300);
 ShowSerialData();
 delay(2000);
 ShowSerialData();
 delay(3000);
 ShowSerialData();
 delay(2000);
 ShowSerialData();
 delay(4000);
 ShowSerialData();
 String temperature = "30";//
 String barometer = "60.56";//
 delay(500);
 ShowSerialData();
 delay(500);
 ShowSerialData();
 delay(500);
 ShowSerialData();
 delay(500);
 ShowSerialData();
 delay(500);
 ShowSerialData();
 delay(500);
 ShowSerialData();
 delay(500);
 ShowSerialData();
 delay(500);
 ShowSerialData();
 delay(500);
 ShowSerialData();
 delay(500);
 ShowSerialData();
 mySerial.println();
 ShowSerialData();
 delay(100);
 ShowSerialData();
void ShowSerialData()
Schematics
File:GPRSshield_sch.pdf
Resources
SIM900_hd_v1.06.pdf
solutions for no registration to network
Solutions
If you are using a Router rather than a modem or Exchanger, before networking testing for the GPRS module, you should pay attention to the following tips.
1. Specify a fixed IP address for Local Host,hereinafter referred to as ’Local Host IP’.
2. Set a Port Mapping on the Router and map the port to Local Host IP. We call the set port ‘Local Host Port’. Local Host Port is within 0 and 65535.
3. Open home page (Google), input” IP” to check your Public IP.
FAQS
Q1. Why should I specify a ‘Local Host Port’ on the Router (Port Mapping)? ADSL dials through a router and the host shares network through the router. In this case, the host usually extracts Private IP such as 192.168.x.x. for such reasons, only when you specify a ‘Local Host Port’ on the Router (Port Mapping) and forward it to the corresponding Local Host, can the Internet access to the Local Host through this Port.
Q2. Why should I specify a Fixed Private IP for the Local Host? Port Mapping is a one-to-one process. If the Local Host is specified to obtain IP automatically, the IP address will probably change when the computer restarts or reconnects to the network. Therefore, it is necessary to specify a Fixed Private IP.
Tools
1. Arduino IDE
2. Net Assist
3. STC-SIP
Steps
1, Start the “Net Assist”, choose ‘TCP server’ in the dropdown menus of “protocol” (UDP Server is not recommended), change the “Local Host IP” into the Fixed IP. Input the “Local host port” set before and then click “Connect “. As shown in following the picture. File:Gprs
2, Open STC-ISP and click ‘COM Helper’ Click ‘COM Port’ and click 115200 in ‘Baud rate’ ( if the code is unreadable in RX Buffer, then re-click Baud rate) , click “Open COM” File:Gprs (2)
Input the following code in the text box of “TX Buffer” and then press “Enter”.
 AT+CLPORT=”TCP”,”2022”
Click “Send Data”. If t he “RX Buffer” shows” ok”, it is successful.
 OK
File:Gprs (3) File:Gprs (4)
Input in “TX Buffer” as follows,
(NB.IP “183.37.246.171” is a Public IP from Google; “10000” is the “Local Host Port”). And then click “Send Data”. The “RX Buffer” will appear
 OK
 CONNECT OK
File:6 3, Verify the success of communication Input
 AT+CIPSEND
in “TX Buffer”, then press “Enter”. Click “Send Data” and the “RX Buffer” appears
as follows. File:7
Input
 HELLO WORLD
in “TX Buffer” and click “Send Data”, check “HEX-Mode”.
Meanwhile, input
 1A
to end instruction and click “Send Data”. It is successful when you see
 SEND OK
File:8 File:9
Now,‘Helloword’ will appear in “NetAssist”. File:10 Select the corresponding IP address and click “Send”. “RX Buffer” dialog in STC-ISP will accept the information returned as below.
File:11
