Arduino GPRS Shield
- GPRS multi-slot class 10/8
- GPRS mobile station class B
- Compliant to GSM phase 2/2+
- RTC supported.
- Selectable serial port.
- Speaker and Headphone jacks
Application Ideas
Cautions
Hardware Diagram
- Pins usage on Arduino
- D2 - Unused
- D3 - Unused
- D4 - Unused
- D5 - Unused
- D6 - Unused
- D10 - Unused
- D11 - Unused
- D12 - Unused
- D13 - Unused
- D14(A0) - Unused
- D15(A1) - Unused
- D16(A2) - Unused
- D17(A3) - Unused
- D18(A4) - Unused
- D19(A5) - Unused
Getting Started
- Insert a unlock SIM card
- Assemble the GSM antenna
Indicator LEDs
Power Up the GPRS Shield
void powerUp()
pinMode(9, OUTPUT);
digitalWrite(9,LOW);
delay(1000);
digitalWrite(9,HIGH);
delay(2000);
delay(3000);
void powerDown()
pinMode(9, OUTPUT);
delay(1000);
delay(2000);
delay(3000);
UNDER-VOLTAGE WARNNING
OVER-VOLTAGE WARNNING
UNDER-VOLTAGE POWER DOWN
OVER-VOLTAGE POWER DOWN
+CMTE:1
+CMTE:-1
+CMTE:2
+CMTE:-2
Upload Sketch to Arduino
//at 19200 bps 8-N-1
#include <SoftwareSerial.h>
SoftwareSerial GPRS(7, 8);
int count=0; // counter for buffer array
GPRS.begin(19200); // the GPRS baud rate
Serial.begin(19200); // the Serial port of Arduino baud rate.
if (GPRS.available()) // if date is comming from softwareserial port ==> data is comming from gprs shield
while(GPRS.available()) // reading data into char array
buffer[count++]=GPRS.read(); // writing data into array
if(count == 64)break;
Serial.write(buffer,count); // if no data transmission ends, write buffer to hardware serial port
clearBufferArray(); // call clearBufferArray function to clear the storaged data from the array
count = 0; // set counter of while loop to zero
if (Serial.available()) // if data is available on hardwareserial port ==> data is comming from PC or notebook
GPRS.write(Serial.read()); // write it to the GPRS shield
void clearBufferArray() // function to clear buffer array
for (int i=0; i<count;i++)
{ buffer[i]=NULL;} // clear all index of array with command NULL
+CFUN: 1
+CPIN: READY
Call Ready
SoftwareSerial library Notes
A Simple Source Code Examples
IDE: Arduino 1.0 or later
to your account at cosm.com
#include <String.h>
mySerial.begin(19200); // the GPRS baud rate
delay(500);
switch(Serial.read())
case 't':
SendTextMessage();
break;
case 'r':
DialVoiceCall();
break;
case 'd':
DialVoiceCall();
break;
case 'h':
SubmitHttpRequest();
break;
case 's':
Send2Pachube();
break;
if (mySerial.available())
///SendTextMessage()
void SendTextMessage()
mySerial.print("AT+CMGF=1\r"); //Because we want to send the SMS in text mode
delay(100);
delay(100);
delay(100);
delay(100);
mySerial.println();
void RecieveTextMessage()
//delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
mySerial.println();
//return r;
///DialVoiceCall
void DialVoiceCall()
delay(100);
mySerial.println();
///SubmitHttpRequest()
void SubmitHttpRequest()
mySerial.println("AT+CSQ");
delay(100);
delay(100);
ShowSerialData();
delay(1000);
ShowSerialData();
delay(4000);
ShowSerialData();
delay(2000);
ShowSerialData();
delay(2000);
ShowSerialData();
delay(1000);
ShowSerialData();
ShowSerialData();
delay(300);
ShowSerialData();
mySerial.println("");
delay(100);
///send2Pachube()///
void Send2Pachube()
delay(100);
ShowSerialData();
delay(1000);
ShowSerialData();
delay(300);
ShowSerialData();
delay(2000);
ShowSerialData();
delay(3000);
ShowSerialData();
delay(2000);
ShowSerialData();
delay(4000);
ShowSerialData();
String temperature = "30";//
String barometer = "60.56";//
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
mySerial.println();
ShowSerialData();
delay(100);
ShowSerialData();
void ShowSerialData()
Schematics
Resources
SIM900_hd_v1.06.pdf
solutions for no registration to network
Solutions
If you are using a Router rather than a modem or Exchanger, before networking testing for the GPRS module, you should pay attention to the following tips. 1. Specify a fixed IP address for Local Host,hereinafter referred to as ’Local Host IP’. 2. Set a Port Mapping on the Router and map the port to Local Host IP. We call the set port ‘Local Host Port’. Local Host Port is within 0 and 65535. 3. Open home page (Google), input” IP” to check your Public IP.
FAQS
Q1. Why should I specify a ‘Local Host Port’ on the Router (Port Mapping)? ADSL dials through a router and the host shares network through the router. In this case, the host usually extracts Private IP such as 192.168.x.x. for such reasons, only when you specify a ‘Local Host Port’ on the Router (Port Mapping) and forward it to the corresponding Local Host, can the Internet access to the Local Host through this Port.
Q2. Why should I specify a Fixed Private IP for the Local Host? Port Mapping is a one-to-one process. If the Local Host is specified to obtain IP automatically, the IP address will probably change when the computer restarts or reconnects to the network. Therefore, it is necessary to specify a Fixed Private IP.
Tools
1. Arduino IDE 2. Net Assist 3. STC-SIP
Steps
1, Start the “Net Assist”, choose ‘TCP server’ in the dropdown menus of “protocol” (UDP Server is not recommended), change the “Local Host IP” into the Fixed IP. Input the “Local host port” set before and then click “Connect “. As shown in following the picture. File:Gprs
2, Open STC-ISP and click ‘COM Helper’ Click ‘COM Port’ and click 115200 in ‘Baud rate’ ( if the code is unreadable in RX Buffer, then re-click Baud rate) , click “Open COM” File:Gprs (2)
Input the following code in the text box of “TX Buffer” and then press “Enter”.
AT+CLPORT=”TCP”,”2022”
Click “Send Data”. If t he “RX Buffer” shows” ok”, it is successful.
OK
Input in “TX Buffer” as follows,
(NB.IP “183.37.246.171” is a Public IP from Google; “10000” is the “Local Host Port”). And then click “Send Data”. The “RX Buffer” will appear
OK CONNECT OK
File:6 3, Verify the success of communication Input
AT+CIPSEND
in “TX Buffer”, then press “Enter”. Click “Send Data” and the “RX Buffer” appears
as follows. File:7
Input
HELLO WORLD
in “TX Buffer” and click “Send Data”, check “HEX-Mode”.
Meanwhile, input
1A
to end instruction and click “Send Data”. It is successful when you see
SEND OK
Now, ‘Helloword’ will appear in “NetAssist”.
File:10 Select the corresponding IP address and click “Send”. “RX Buffer” dialog in STC-ISP will accept the information returned as below.
