Hot End V2.0
The HotEnd V2.0 version is a high performance hotend for use with RepRap and other 3D printers,making your printing even faster. The hot end comes completely assembled: wire it to your electronics and it is ready to print. It now includes an aluminum mount plate and aluminum heat sinks. The HotEnd V2.0 also brings changes to the nozzle, heater block, and threaded extension with harder aluminum and revised thread profile for more reliable nozzle changes.
This product adopts Teflon and aluminum alloy heat radiator for heat dissipation and duralumin alloy nozzle. Its surface is covered with anodic oxide coating, which can resist oxidation corrosion and increase nozzle hardness. Since the heat-insulated pipe is designed with Teflon, the material will not soften easily, thus ensuring finer and more stable printing.
Product Introduction
| Molding form | FDM |
| Material | Metal |
| Movement speed | 50cc |
| Outline dimensions | 66*70*40mm L/H/W) |
| Weight | 120g |
| Thermisto | 100K 1% high-precision NTC Thermistor |
Click here to buy HotEnd V2.0
