Teensylu
- Logic supplied by USB bus
- on-board USB connectivity
- UART1 (RX and TX)
- I2C (SDA and SCL)
- SPI (MOSI, MISO, SCK)
- PWM pin (1)
- Analog I/O (6)
Compatible Firmwares
- Sprinter
- Marlin
- Repetier
Building Firmware
Sprinter(compatible for Arduino 023)
- Download the arduino environment and install. http://arduino.cc/en/Main/Software
- Download the Teensyduino library from pjrc and install. Be sure to select "all" when asked which additional libraries to install
- Download Sprinter firmware. https://github.com/kliment/Sprinter
- Open Sprinter in arduino and configure configuration.h file.
- Motherboard should be set to 8: #define MOTHERBOARD 8
- Turn off endstops if you didn't install endstops: const bool ENDSTOPS_INVERTING = true;
- Turn comment out SD card support, not working yet: //#define SDSUPPORT
- Go to Tools menu and set Board to Teensy++ 2.0, or Teensylu if using alternate bootloader
- Go to Sketch menu and click "Verify/Compile"
- A program will popup for the teensy programmer after sprinter is done compiling
- open the HEX File in teensy loader and move sprinter.cpp.hex to root folder of C drive for programming
Programming the Firmware
Windows
- Windows will find the new hardware as the virtual com port. If windows find the unrecognized hardware, install the USB Serial driver
- Install the WinAVR
Schematics
Burn the bootloader
Click here to buy Teensylu
