Breakout Board for microSD Transflash
Compatible with the SPI interface found on any SD card, this tiny form factor was created for cell phone storage and is perfect for your next MP3 project!
- SPI mode
- Support voltage:3.0 to 3.6V
- Sits directly on a Arduino
Sometime you're not sure whether a card is working or not,you must test it.
// include the SD library:
- include <SD.h>
// set up variables using the SD utility library functions: Sd2Card card; SdVolume volume; SdFile root; // change this to match your SD shield or module; // Arduino Ethernet shield: pin 4 // Adafruit SD shields and modules: pin 10 // Sparkfun SD shield: pin 8 const int chipSelect = 4; void setup() {
while (!Serial) {
Serial.print("\nInitializing SD card..."); // On the Ethernet Shield, CS is pin 4. It's set as an output by default. // Note that even if it's not used as the CS pin, the hardware SS pin // (10 on most Arduino boards, 53 on the Mega) must be left as an output // or the SD library functions will not work.
pinMode(10, OUTPUT); // change this to 53 on a mega
// we'll use the initialization code from the utility libraries // since we're just testing if the card is working! if (!card.init(SPI_HALF_SPEED, chipSelect)) { Serial.println("initialization failed. Things to check:"); Serial.println("* is a card is inserted?"); Serial.println("* Is your wiring correct?"); Serial.println("* did you change the chipSelect pin to match your shield or module?"); return;
} else {
// print the type of card Serial.print("\nCard type: "); switch(card.type()) {
case SD_CARD_TYPE_SD1:
Serial.println("SD1");
break;
case SD_CARD_TYPE_SD2:
Serial.println("SD2");
break;
case SD_CARD_TYPE_SDHC:
Serial.println("SDHC");
break;
default:
Serial.println("Unknown");
// Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32 if (!volume.init(card)) {
return;
uint32_t volumesize;
Serial.println();
Serial.println(volumesize);
volumesize /= 1024;
volumesize /= 1024;
root.openRoot(volume);
void loop(void) {
