Tiny210 Overview
Revision as of 02:14, 6 July 2012 by Admin (talk | contribs)
  • 1GHz Samsung S5PV210 with PowerVR SGX540 graphics engine
  • 512MB DDR2 RAM and 1GB NAND Flash
  • LCD/Touch Screen, HDMI,TV out, Audio support
  • TF card, USB Host/OTG support
  • Ethernet, WiFi, serial port, GPIO
  • Contain CPU board
  • Linux 2.6.35 & Android 2.3 support
CPU board Hardware info
Multi-IO: 2 x 60 Pin 2.0mm space DIP connector
1 x 30 Pin 2.0mm space DIP connector
1 x 51 Pin 1.0mm space SMD connector
on Board: HDMI interface 4 x User Leds(Green)
1 x Power Led(Red)
Supply Voltage from 2V to 6V
Mechanical: Dimension: 64x 50x 11mm
Software: Android 4.0, Android 2.3, Linux 2.6.35, Qtopia-2.2.0/Qt-4.4.3/Qt-4.7
Tiny210 Motherboard
  1. Integrated USB 2.0 Hub: Extended 4 USB host ports, three of them as the standard side port,and one was lead by SCON interface
  2. AV CCD Camera In: Integrated TVP5150 video chip: 2 AV input port (RCA), can be directly connected using a CCD camera
  3. RS485: 1 RS485 interface
  4. Serial Port: 4 serial port, two of them have been converted to RS232, and leads through the DB9 Block (COM0, COM1), through the CON1, 2, 3, 4, Block leads to TTL level
  5. keys: 8 key
  6. RJ45 Ethernet port: using DM9000AEP, 10/100M adaptive
  7. Audio input and output: using the WM8960 professional audio chip, containing Class D amplifier on-board microphone, and supports HDMI audio and video synchronization output
  8. USB Slave: 1 Road, the USB 2.0 specification
  9. Infrared receiver: 1
  10. ADC input: 6 ADC input
  11. Buzzer: 1, control by the PWM0
  12. EEPROM:AT24C08 (256 Byte) for I2C test
  13. LCD Interface: 2 LCD interface, both 40 Pin 0.5mm Pitch Chip Block, support 3.5 "-19" full color TFT display LCD
  14. SDIO interface: used to connect the SDWiFi module and other
  15. CMOS Camera interface: used to connect CMOS camera
  16. RTC clock: with a backup battery (according to different regions or time periods, mailing may remove the battery)
  17. PCB layer: 2
  18. PCB size: 180 x 130mm, can be easily fixed all kinds of LCD modules, especially the 7-inch LCD module
  19. Power supply: DC-5V
Linux&Android 2.3
  • Boot loader
verison: Superboot-210
Function: support boot and update system by TF-card(superboot)
  • Linux kernel
verison: Linux-2.6.35
Compile: arm-linux-gcc-4.5.1-v6-vfp
  • Device Driver
TFT LCD/Touchscreen, HDMI, Audio OUT, MMC/SD card, NET, Serial port, watchdog,RTC, keyboard
WIFI, USB Host/Device, FIMC/JPEG/MFC/3D/2D, Camera, 3Gdriver
  • File Systemsupport
Ubi filesystem, yaffs, ext2/3,
  • Function use example
Ethernet, Support DHCP, Audio in/out, SD WiFi support, HDMI support
OMS Camera support, 3G support(WCDMA, CDMA2000)
USB Disk support, USB Bluetooth support, Switch horizontal and vertical screen
Dynamic Wallpapers
Linux
  • Boot loader
  • Linux kernel
  • Device Driver
  • Graphics system
Tiny 210
