Arduino Mega 2560
Revision as of 01:32, 4 January 2012 by Admin (talk | contribs) (→Summary)
The Arduino Mega 2560 is a microcontroller board based on the ATmega2560 (datasheet). It has 54 digital input/output pins (of which 14 can be used as PWM outputs), 16 analog inputs, 4 UARTs (hardware serial ports), a 16 MHz crystal oscillator, a USB connection, a power jack, an ICSP header, and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started. The Mega is compatible with most shields designed for the Arduino Duemilanove or Diecimila.
The Mega 2560 is an update to the Arduino Mega, which it replaces.
Schematic, Reference Design & Pin Mapping
EAGLE files: arduino-mega2560-reference-design.zip
Schematic: arduino-mega2560-schematic.pdf
Pin Mapping: PinMap2560 page
Microcontroller ATmega2560
Operating Voltage 5V
Input Voltage (recommended) 7-12V
Input Voltage (limits) 6-20V
Analog Input Pins 16
DC Current per I/O Pin 40 mA
DC Current for 3.3V Pin 50 mA
SRAM 8 KB
EEPROM 4 KB
Clock Speed 16 MHz
Memory
Input and Output
Communication
Programming
Automatic (Software) Reset
USB Overcurrent Protection
Physical Characteristics and Shield Compatibility
