Arduino Mega 2560
Revision as of 01:31, 4 January 2012 by Admin (talk | contribs) (→Overview)
The Arduino Mega 2560 is a microcontroller board based on the ATmega2560 (datasheet). It has 54 digital input/output pins (of which 14 can be used as PWM outputs), 16 analog inputs, 4 UARTs (hardware serial ports), a 16 MHz crystal oscillator, a USB connection, a power jack, an ICSP header, and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started. The Mega is compatible with most shields designed for the Arduino Duemilanove or Diecimila.
Schematic, Reference Design & Pin Mapping
Memory
Input and Output
Communication
Programming
Automatic (Software) Reset
USB Overcurrent Protection
Physical Characteristics and Shield Compatibility
