Micro2440
Revision as of 08:36, 5 July 2012 by Admin (talk | contribs)
Micro2440 | S3C2440 ARM9 Stamp Module
FriendlyARM Micro 2440 Stamp Module with 400 MHz Samsung S3C2440 ARM9 processor.
Micro2440 Schematics
Specification: Stamp Module
  • Dimension: 63 x 52 mm
  • CPU: 400 MHz Samsung S3C2440A ARM920T (max freq. 533 MHz)
  • RAM: 64 MB SDRAM, 32 bit Bus
  • Flash: 64 MB / 128 MB / 256 MB / 1GB NAND Flash and 2 MB NOR Flash with BIOS
  • Serial, SPI, USB, LCD, CMOS Camera Interface
  • Analog Input and Output
  • User Outputs: 4x LEDs
  • Expansion headers (2.0 mm)
  • Debug: 10 pin JTAG (2.0 mm)
  • OS Support
    • Windows CE 5 and 6
    • Linux 2.6
    • Android
Specification: SDK-Board
  • Dimension: 180 x 130 mm
  • EEPROM: 1024 Byte (I2C)
  • Ext. Memory: SD-Card socket
  • Serial Ports: 3x DB9 connector (RS232)
  • USB: 4x USB-A Host 1.1, 1x USB-B Device 1.1
  • Audio Output: 3.5 mm stereo jack
  • Audio Input: 3.5mm jack (mono) + Condenser microphone
  • Ethernet: RJ-45 10/100M (DM9000)
  • RTC: Real Time Clock with battery
  • Beeper: PWM buzzer
  • Camera: 20 pin Camera interface (2.0 mm)
  • LCD: 41 pin connector for FriendlyARM Displays and VGA Board
  • Touch Panel: 4 pin (resistive)
  • User Inputs: 6x push buttons and 1x A/D pot
  • Power: regulated 5V (DC-Plug: 1.35mm inner x 3.5mm outer diameter)
Click here:http://www.geeetech.com/armavr-series-arm9-c-9_11.html
