IR Transmitter and Receiver Kit
IR Transmitter
IR trnsmitter module can emit modulated 38KHz signal via Arduino programming to achieve simulate common remote control.
IR Receiver
IR Receiver Module is an Arduino compatible 38Khz IR detector which can detect modulated 38Khz around IR signal. Though programming Arduino ,IR receiver can achieve the fuction of decoding the remote control signal.
- Power Supply:5V
- Interface:Digital
- Modulate Frequency:38Khz
Applications
- Remote control
- TV control
- Air conditioning control
Wiring diagram
Transmitter
#include <IRremote.h>
IRsend irsend;
void loop() {
for (int i = 0; i < 50; i++) {
irsend.sendSony(0xa90, 12); // Sony TV power code
delay(40);
Receiver
IRrecv irrecv(RECV_PIN);
decode_results results;
void loop() {
- Note
- Led on the IR transmitter module should be directed at IR detector on the receiving board for better result. If the infrared LED is not directed well at the IR detector, the IR detector on the receiving board cann't detect the modulated IR signals well and it will cause the decoded signal incorrect.
Click here to buy IR Transmitter Module and IR Receiving Module
