Arduino Digital Vibration Sensor module
The Arduino vibration sensor module is based on vibration switch component which can detect the weak vibration signals. The sensor can work for vibration-related modules.
Product Performance:
- The conductive pin will make an instant turn-on (ON) state when touched by the outside force to achieve the proper vibration force, or an appropriate speed from the (partial) energy.
- No direction, any angle may burst.
- The switch is suitable for small-current circuit (secondary circuit) or (IC) of the trigger.
- At room temperature and normal use the next switch service life is up to 10 million times (times/1sec).
On-Time: 0.1ms
Open circuit resistance: 10Mohm
Pin definition
VCC - 5V GND - GND S - Digital pin3
int ledPin = 13; // Connect LED to pin 13
int switcher = 3; // Connect Tilt sensor to Pin3
pinMode(ledPin, OUTPUT); // Set digital pin 13 to output mode
pinMode(switcher, INPUT); // Set digital pin 3 to input mode
if(digitalRead(switcher)==HIGH) //Read sensor value
digitalWrite(ledPin, HIGH); // Turn on LED when the sensor is tilted
delay(300);
else
digitalWrite(ledPin, LOW); // Turn off LED when the sensor is not triggered
How to buy it
Click here to buy vibration sensor
