Geeetech M1 3D printer
Revision as of 03:28, 5 January 2026 by Admin (talk | contribs) (How to Import Profiles into Cura)
Printer Introduction
Appearance
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
Power Input:
Net Weight(kg): 3 kg
Gross Weight(kg): 4 kg
How to clean the hotend
How to Replace the hotend
How to replace the nozzle
How to Replace the Screen
How to Replace the Extruder
How to Automatically Level
How to Manually Level
How to adjust the X-axis belt
How to install a detached print head
How to remove the upper frame
How to remove the middle frame
How to Replace a Heated Bed Kit
Mainboard wiring diagram
M1 1KG consumables installation video
Download link of M1 1KG model file
Black Screen
Minimum Temperature Error
Filament cannot be extruded
3、 The printer is blocked
Solution:
Print file is not displayed
M1 Cura Configuration Files
(2) Click Import
(3) Click Import Configs...
4、 Click Yes for all
3.The extruder is not working
Rough edges and corners
The side edges are uneven
How to print PLA
Nozzle temperature: 190-210℃
Bed temperature: 30-60℃
Fan Cooling: 100%
Nozzle temperature: 220-240℃
Fan Cooling: 100%
