Geeetech M1 3D printer
Printer Introduction
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
Power Input:
Net Weight(kg): 3 kg
Gross Weight(kg): 4 kg
How to Clean the Nozzle
How to Replace the Hot End
How to Replace the Screen
How to Automatically Level
How to Manually Level
Black Screen
Minimum Temperature Error
2、 Open the location of the Cura slicing software and copy the geeetech_M1.def.json file to the target path: \UltiMaker Cura 5.8.1sharecuraresourcesdefinitions
3、Copy all the configuration files in the image
4、 Copy all geeetech_M1.inst.cfg files to this path: \UltiMaker Cura 5.x.x\share\cura\resources\variants\geeetech_variants
(2) Click Import
(3) Click Import Configs...
3.The extruder is not working
Rough edges and corners
The side edges are uneven
How to print PLA
Nozzle temperature: 190-210℃
Bed temperature: 30-60℃
Fan Cooling: 100%
Nozzle temperature: 220-230℃
Fan Cooling: 100%
How to print ABS
Nozzle temperature: 230-250℃
Bed temperature: 90-110℃
Fan Cooling: 0%
How to print PETG
Nozzle temperature: 220-250℃
Bed temperature: 70-80℃
Fan Cooling: 100%
