Filament
Revision as of 09:01, 15 June 2024 by Admin (talk | contribs)
PLA
Bed temperature: 60-70 °C
Print speed: 60-100 mm/s
Initial layer height: 0.3 mm
Initial layer print speed: 20 mm/s
Travel Speed: At least 120 mm/s
Retraction distance: 6 mm for Bowden setups, 2-3 mm for direct drive setups
Retraction speed: 45 mm/s
Cooling fan speed:100%
(1) Level the hotbed
(2) Change the Z-offset
(3) Clean the hotbed
Silk PLA keeps clogging
Wood PLA keeps clogging
Carbon Fiber PLA
PLA carbon fiber filament is a composite material, usually made of a mixture of polylactic acid (PLA) and carbon fiber.
(1) PLA carbon fiber filament has the following characteristics:
(2) Matters needing attention when using PLA carbon fiber filament:
Clean the nozzle: Clean the nozzle and extruder regularly to prevent carbon fiber particles from accumulating.
High Speed PLA
PETG
Bed temperature: 70-80 °C
Print speed: 40-50 mm/s
Retraction speed: 25 mm/s
Cooling fan speed: 30-40%
Build plate adhesion: Brim
ABS
Bed temperature: 80-100 °C
Cooling fan speed: 0%
TPU
Nozzle temperature: 200-210°C
Bed temperature: 60 °C
Print speed: 30-40 mm/s
Applicable to Bambu Lab AMS LITE
001 002 003
004 005
Solution for consumables entangled with each other
