Filament
PLA
Bed temperature: 60-70 °C
Print speed: 60-100 mm/s
Initial layer height: 0.3 mm
Initial layer print speed: 20 mm/s
Travel Speed: At least 120 mm/s
Retraction distance: 6 mm for Bowden setups, 2-3 mm for direct drive setups
Retraction speed: 45 mm/s
Cooling fan speed:100%
(1) Level the hotbed
(2) Change the Z-offset
(3) Clean the hotbed
Silk PLA keeps clogging
Wood PLA keeps clogging
Carbon Fiber PLA
PLA carbon fiber filaments are a composite material, usually made of a mixture of polylactic acid (PLA) and carbon fiber. At the same time, PLA carbon fiber filaments have the following characteristics:
High strength and high rigidity: Combines the easy printability of PLA with the high strength and rigidity of carbon fiber.
When using PLA carbon fiber filaments, things to pay attention to: Nozzle selection: It is recommended to use a nozzle of 0.4 mm or larger to avoid clogging.
Printing temperature: The nozzle temperature is maintained at 200°C to 230°C, and the hot bed temperature is set at 50°C to 60°C to avoid material clogging or printing quality problems
Clean the nozzle: Clean the nozzle and extruder regularly to prevent carbon fiber particles from accumulating.
High Speed PLA
PETG
Bed temperature: 70-80 °C
Print speed: 40-50 mm/s
Retraction speed: 25 mm/s
Cooling fan speed: 30-40%
Build plate adhesion: Brim
ABS
Bed temperature: 80-100 °C
Cooling fan speed: 0%
TPU
Nozzle temperature: 200-210°C
Bed temperature: 60 °C
Print speed: 30-40 mm/s
Applicable to Bambu Lab AMS LITE
Solution for consumables entangled with each other
