Mizar M
Unique Separated Color Module
Product details
Main specification
Technology: FDM
Printing Thickness: 0.1-0.2mm
Nozzle Diameter: 0.4mm
Printing Accuracy: ±0.1mm
Printing Speed: 20~150mm/S
Hotbed Max Temperature: 110℃
Nozzle Max Temperature: 250℃
Working temperature: 10-40℃
Electric Parameter
Hotbed Size: 260*260mm
Net Weight: 10.2kg
Gross Weight: 13kg
Unpacking and proper handling
Slicing
Cura
Mizar M Cura Configuration
File Path
Cura 5.X
Cura 4.X
Cura Profile
Separate Color Printing
Gradient Color printing
- G-code Instructions
M163 Set a mix factor
M164 Save mix factor
M166 Gradient for Marlin 2.0
A= Start z height
Z= End z height
I= Start Virtual Tool
J= End Virtual Tool
M163 S0 P1
M163 S1 P0
M164 S0 ;T0=100/0
M163 S0 P1; 100% Red
M163 S1 P0; 0% Green
M163 S0 P0; 0% Red
M163 S1 P1; 100% Green
M166 A0 Z250 I0 J1 S1
mix.
M166 A0 Z250 I0 J1 T3
T3
M166 T
T0
M163 S0 P1
M163 S1 P0
M164 S0 ;T0=100/0
M163 S0 P0
M163 S1 P1
M164 S1 ;T1=0/100
M163 S0 P0.5
M163 S1 P0.5
M164 S2 ;T2=50/50
M163 S0 P1
M163 S1 P0
M164 S0 ;T0=100/0
M163 S0 P0
M163 S1 P1
M164 S1 ;T1=0/100
M163 S0 P0.5
M163 S1 P0.5
M164 S2 ;T2=50/50
Easy Print
Gradient Color Printing
Prusa Slicer
Mizar M Prusa Configuration
Separate Color Module
Simplify 3D
Printer maintenance
| Warning |
| Never install or unplug anything on a printer while it’s being powered! |
Warning:
(a)Please check if the power supply is working normally. The red indicator on the switch should be light. Please measure the output voltage, which should be around 24 Volts. And also check the fuse in the little black box, it should be complete without burns.
