Real Time Clock RTC DS1307 Module
DESCRIPTION
FEATURES
- Real-time clock (RTC) counts seconds,minutes, hours, date of the month, month, daof the week, and year with leap-year compensation valid up to 2100
- 56-byte, battery-backed, nonvolatile (NV) RAM for data storage
- Two-wire serial interface
- Programmable squarewave output signal
- Automatic power-fail detect and switch circuitry
- Consumes less than 500nA in battery backup mode with oscillator running
- Optional industrial temperature range:-40°C to +85°C
- Available in 8-pin DIP or SOIC Underwriters Laboratory (UL) recognized
PIN DESCRIPTION
VCC - Primary Power Supply
X1, X2 - 32.768kHz Crystal Connection
Vbat - +3V Battery Input
GND - Ground
SDA - Serial Data SDA is the input/output pin for the 2-wire serial interface. The SDA pin is open drain which requires an external pullup resistor.
SCL - Serial Clock SCL is used to synchronize data movement on the serial interface.
X1, X2 – Connections for a standard 32.768kHz quartz crystal. The internal oscillator circuitry is designed for operation with a crystal having a specified load capacitance (CL) of 12.5pF.
