Mizar M
Product details
Main specification
Technology: FDM
Printing Thickness: 0.1-0.2mm
Nozzle Diameter: 0.4mm
Printing Accuracy: ±0.1mm
Printing Speed: 20~150mm/S
Hotbed Max Temperature: 110℃
Nozzle Max Temperature: 250℃
Working temperature: 10-40℃
Electric Parameter
Hotbed Size: 260*260mm
Net Weight: 10.2kg
Gross Weight: 13kg
Unpacking and proper handling
Slicing
Cura
Mizar M Cura Configuration
File Path
Cura 5.X
Cura 4.X
Cura Profile
Separate Color Printing
Applied to both Mix-Color module and Separate-Color module
Gradient Color printing
Make sure to install the Gradient Color module in advance
- G-code Instructions
- M163 Set a mix factor
- M164 Save mix factor
- M166 Gradient for Marlin 2.0
- A= Start z height
- Z= End z height
- I= Start Virtual Tool
- J= End Virtual Tool
- S= Enable / disable the gradient in manual mode
- T=A tool index to reassign to the gradient. If no index is given, cancel the tool assignment.
M163 S0 P1
M163 S1 P0
M164 S0 ;T0=100/0
- Then we create the first Tools T0, which will be red.
M163 S0 P1; 100% Red
M163 S1 P0; 0% Green
- Now save this color scheme in our Tools T0 we use the command
- M164 S (index), where index is our Tools, and then click
M163 S0 P0; 0% Red
M163 S1 P1; 100% Green
M166 A0 Z250 I0 J1 S1
mix.
M166 A0 Z250 I0 J1 T3
T3
M166 T
T0
M163 S0 P1
M163 S1 P0
M164 S0 ;T0=100/0
M163 S0 P0
M163 S1 P1
M164 S1 ;T1=0/100
M163 S0 P0.5
M163 S1 P0.5
M164 S2 ;T2=50/50
- In this example no tool index is assigned to the Gradient. So the Gradient is enabled using M166 S1 and disabled with M166 S0
M163 S0 P1
M163 S1 P0
M164 S0 ;T0=100/0
M163 S0 P0
M163 S1 P1
M164 S1 ;T1=0/100
M163 S0 P0.5
M163 S1 P0.5
M164 S2 ;T2=50/50
- In this example the Gradient has been given a tool alias of 3. So the Gradient is selected with , and all other commands will select a static mix.
