Geeetech GTM32 Board
GTM32 is a fully self-developed control board by Geeetech for high-performance 3D printers. It keeps Geeetech’s uniformly optimized interface specifications, easy to assemble and with compact layout, high integration and high performance.
GTM32 control board (hereinafter referred to as the control board) adopts the current mainstream high-performance Cortex M3 core chip STM32F103, with its running frequency of up to 72MHz.The control board supports up to 4 stepper motors, namely, XYZ axial motor and an extruder. Users can replace the driving modules, such as A4988 and TMC2100 modules, according to their own needs. Besides, it employs the high performance USB serial chip FT232RL, which enables users to manipulate the control board via USB cable. Its output voltage is 12V.
i. With a buzzer on board.
Hardware Resources
5. 6 endstop interfaces
7. 3 interfaces for PWM fan
8. 3D Touch interface
Weight: 79.00 g
Interface specifications:
USB interface: USB B type
Software resources
3D Printing and control software:
1. PSU: output voltage 12V
2. Hotbed interface:
3. Extruder interface:
Subdivision of Stepper Motor
X,Y,Z axis stepper motors
Extruder stepper motors
Turn ON/OFF Subdivision
MS1 MS2 MS3
OFF OFF OFF full step
ON OFF OFF 1/2 step
OFF ON OFF 1/4 step
ON ON OFF 1/ 8 step
ON ON ON 1/16 step
Pay attention to the Plus-n-Minus of the power connector, reverse connection can cause irrevocable damages.
A4988 should also be connected to the right port, mismatches and revered directions can cause damage to the main board. Please notice the color of the pins and connect the same colored pins together. If some pins are not color-labelled, pleased follow the picture below.
Install FT232RL Driver
After downloading, double-click the .exe file to finish the installation.
Windows will prompt that a new USB Serial Port is detected, now you can check the device manager, you will see a new port named“USB Serial Port”
How to Install firmware
1. Download “toolkit-os” and upzip the file. Here is the link Firmware-download-tool
2. Connect your 3D printer with a computer. Double click “main.exe” to start upgrading the firmware for GTM32 control board. A window will pop up, showing the COM port for your 3D printer.
3. Click “Select” to choose the new firmware you’ve written, for instance, “GTM32.bin”.
4. Click “Upgrade” and the upgrading will start automatically.
5. When the firmware is upgrade successfully, you will see the following window. Close the window to finish the whole process.
Open Source Firmware
Quick Start
GTM32 control board is self-developped by Geeetech, compatible with Reprap G.code instructions. It is based on ARM microprocessor STM32F103VET6 to control desktop 3D printer. This control board includes 4 stepper motor drivers (driver module: 4988/2100): for X, Y, Z axis and extruder. The driver module on Z axis could connect 2 stepper motors, enabling dual rods on Z axis. To start 3D printing, the control board also supports 4 stepper motors, 1 extruder, 3 endstops, 1 heatbed and a 12V PSU (Please select a suitable PSU based on the power. We recommend 450W.)
Other expandable features for GTM32 control board include interfaces for Wi-Fi module (for remote controlling your 3D printer), filament detector (reminding you to change filament when the filament runs out or fractures), 3D touch, capacitive proximity sensor (for auto-leveling), and breaking-resuming module (resuming the unfinished print when the printer is powered on again.)
Software-related configuration.
You can modify the printing parameters on the basis of the source code. The baud rate of the GTM32 control board is 115200.
1. In the file “configuration_Select_Printer.h”, you can select the printer types.
/*****************select printer********************/
//#define BOARD_A30_MINI_S 1 //A30 printer
//#define BOARD_A30S_Pro_S 1 //A30S printer
//#define BOARD_E180_MINI_S 1 //E180 Printer
2. File Configuration_XXXXXX.h covers the paremeters of your printer. You can adjust the parameters manually and flash the file into the control board. It is necessary to “restore factory settings” to make the file you’ve modified to work normally.
Eg. Settings for the max temp of heatbed and extruder
Eg. Settings for the moving range of each axis
- define X_MAX_POSITION 320.0
- define Y_MAX_POSITION 320.0
Eg. Settings for the position of endstops
- define HOMEX MINENDSTOP
- define HOMEY MINENDSTOP
- define HOMEZ MINENDSTOP
Eg. Settings for the rotating directions of stepper motors
- define DIR_X POSITIVE
- define DIR_Y POSITIVE
- define DIR_Z POSITIVE
- define DIR_E POSITIVE
- define DIR_E1 OPPOSITE
- define DIR_E2 POSITIVE
Eg. Settings for the micro steps of motors
You can use Repetier-host, Cura, Printrun etc. software to control your 3D printer. Please follow the specific operation steps for each software.
A: One extruder at best.
A: 12V.
