GT2560A/GT2560A+
GT2560 is a compact board that is integrated with the mighty function of the Arduino Mega2560+Ultimaker and Arduino Mega2560+ramps 1.4 on respect of both software and hardware and has more premium features: the streamlined interfaces effectively avoid the unnecessary troubles, well-regulated compaction of components highly integrated saves more space and easier to be mounted on most applications.
5 stepper motors, swappable driving modules, mighty ATmega2560 processor with 256k memory, 16MHz operating frequency, high-performance USB serial converter FT232RQ/CH340, all these make the GT2560 an ideal option for a 3D printer control board. What’s more, GT2560 can run over 12V to 24V which gives higher torque and higher rotation rate.
2. Adopt ATmega2560 as the main control chip, coupled with the high-performance USB serial converter FT232RQ/CH340.
Hardware resources:
12V/24V 15A and 12V/24V 10A power supply
3 input for12V cooling fan
1 PWM output
Dimension: 109mm*78mm*22mm
weight: 87 g
Source
Arduino IDE
Marlin
Printrun
Repetier-Host
Interface specifications
1.DC IN: 12V-24V 15A and 12V-24V 10A 2.HOT_BED: heat bed
5.LCD ENCODER: LCD panel
6.SD Card
2-2
Turn ON/OFF            Subdivision
MS1    MS2    MS3
OFF    OFF    OFF    full step
ON     OFF    OFF    1/2 step
OFF    ON     OFF    1/4 step
ON     ON     OFF    1/ 8 step
ON     ON     ON     1/16 step
MS1    MS2    MS3
ON     OFF    OFF    1/2 step
OFF    ON     OFF    1/4 step
ON     ON     OFF    1/ 8 step
OFF    OFF    ON     1/16 step
ON     OFF    ON     1/32 step
OFF    ON     ON     1/32 step
ON     ON     ON     1/32 step
Software setting
Click "Continue" in Read me.
Click "Continue" in License.
File Burning
firmware, as shown below.
Get Started
#define BAUDRATE 250000
#define MOTHERBOARD 7
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_BED 1
 #define EXTRUDE_MINTEMP 170
#define INVERT_X_DIR false
#define INVERT_Y_DIR true
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_POS 205
#define X_MIN_POS 0
#define Y_MAX_POS 205
#define Y_MIN_POS 0
#define Z_MAX_POS 200
#define Z_MIN_POS 0
I3 PRO B [1]
I3 PRO W [2]
I3 PRO C [3]
I3 PRO X [4]
I3 A PRO [5]
Refer to this website Geeetech official forum
At most 2 extruders, GT2560 supports 5 A4988 stepper motor drivers, they are X/Y/Z axis and 2 extruders.
2.What is the power required?
You need to use the 12V-24V power supply, and if you are using the single extruder one, the total power is no less than 200W, if you are using the dual extruder one, the total power is no less than 240W.
By default in the firmware, only when the temprature of the extruder reaches 170°C can the motor turn.
How to get
Visit here now!
