Humidity /Temperature Sensor Module HSM-20G
Revision as of 02:42, 2 May 2012 by Admin (talk | contribs)
introduction
The module of HSM-20G is essential for those applications where the relative humidity can be converted to standard voltage output.
Applications
  • Humidifiers & dehumidifiers
  • Air-conditioner
  • Humidity data loggers
  • Automotive climate control
  • Other applications
Specifications:
1、Characteristics : HSM-20G
2、Input voltage range : DC 5.0±0.2V
3、Output voltage range : DC 1-3.19V
4、Measurement Accuracy : ±5% RH
5、Operating Current (Maximum) : 2mA
6、Storage RH Range : 0 to 99% RH
7、Operating RH Range : 20 to 95% (100% RH intermittent)
8、Transient Condensation : < 3%RH
9、Storage : -20℃ to 70℃
10、Operating : 0℃ to 50℃
11、Hysteresis (RH @ 25℃) : MAX 2%RH
12、Long Term Stability(typical drift per year) : ±1.5%
13、Linearity : Linearity
14、Time Response(63% step change) : 1 min
15、Dimensions(L*W) : 34mm*22mm*9mm
Typical Response of HSM-20G at 25 ℃
