2.8"TFT LCD
introduction
HY-TFT280 is a 2.8 inch TFT LCD Screen module, 320*240 (resolution), 65K color, 40pins interface , not just a LCD breakout, but include the Touch screen, SD card. So it’s a powerful extension module for your project.
Application Ideas
- Digital Photo Frame (DPF)
- Video terminals
- Instrumentation
- GPS
- Game consoles
Specification:
- 2.8" Color TFT LCD
- 320 x 240 Resolution
- 65,536 Colors (16 Bit)
- Powerful 16 Bit Microcontroller(ILI9331)
- Built-in video RAM buffer
- Integrated SD card
- 5V Operating Voltage
- LED Backlight
pin difinition
Usage:
Display:
- Connect HY-TFT280 to Arduino Mega2560:
LEDA -> 5V LEDK -> GND VCC -> 5V RD -> 3.3V GND -> GND DB0->DB7 to pin D37->D30 DB8->DB15 to pin D22->D29 RS -> D38 WR -> D39 CS(pin6) -> D40 RSET-> D41
- Connect HY-TFT280 to Arduino UNO
LEDA -> 5V LEDK -> GND VCC -> 5V RD -> 3.3V GND -> GND DB0->DB5 to D8->D13 DB6->A0 DB7->A1 DB8->DB15 to D0->D7 RSET->A2 CS->A3 WR->A4 RS->A5
Note: The TFT controller model needs to be declared in the initializing statement. ITDB02 myGLCD(38,39,40,41) needs to be modified as myGLCD(38,39,40,41, TFT01_24) when using Arduino Mega2560.ITDB02 myGLCD(19,18,17,16, TFT01_24) needs to be commented when using Aduino UNO. Otherwise it just show a blank screen. In practice, RS, WR, CS, RSET can be connected to any free pin. But the pin number must be in accord with myGLCD(RS,WR,CS,RST).
Touch Screen:
The LCD has a 2.8" 4-wire resistive touch screen lying over it. The Touch library needs to be installed to get it works. This library is designed for 2.4’’ TFT, 2.8” TFT LCD screen module.
SD Card:
How to buy it
Click here to buy [1]
