Building Instructions of Geeetech Prusa I3 M201
Preparation
=Assemble the threaded rods of Y axis=
Watch the Video here.
- Tips:
You can watch the video here.
Screw up the locking ring
Mount the Y motor
Y belt driving wheel
Build the print platform
Mount the Y belt
- Tips:
Watch the video here.
Left Z motor mount
*Be very careful here, if you can not insert them into the hole you can loose the screw on the motor mount and try again.
Right Z motor mount
Side panel assembly
Mount the Z motors
Mount the Z endstop
Main frame assembly
Fan mount
Mount the fan on the BACK of the left side of the A1. Fix it with 4 M3 x 30mm screw, M3 washer and 4 M3 hex nut.
Mount the couplings
1.Thread a M3 washer> spring> M3 washer in order to the M3x50mm screw.
mount the X motor.
Step 3. Mount the endstop
File:17.Assembly of the extruder carriage 2 .jpg
